If i was over reading the play i'd be saying that you said Tomei pumps are shit and you shouldn't buy them, being you've also kill one :D
They are not shit, there is only select evidence here and there, perhaps as paul said the material has changed, who knows what goes on in a manufacturing plant during tougher times.
Dude I dont know where you get your info But i reccomend you find a new source. The current one is making you look like an asshat.
The only oil pump I have ever purchased and or owned other than the original stocker is a Jun. This pump has survived 2 engine failures. One when the clutch ripped the engine and drivetrain apart and the other when I shat a turbo through the engine.
The oil pump has been apart and inspected and crack tested on both occasions and is now happily singing away on track duty at over 500 rwhp.
The only oil pump I have ever purchased and or owned other than the original stocker is a Jun. This pump has survived 2 engine failures. One when the cluth ripped the engine and drivetrain apart and the other when I shat a turbo through the engine.
that post did 2 things...made me lol and then gave me a warm fuzzy feeling that my JUN pump may live longer than i expect it too. Nice one Fox.
Edited by DiRTgarage
Well i just went by your post
Check out the price of the Jun pump while you're at it. A fair bit less than the tomei item and I have broken about everything except the Jun oil pump to date. :D
Can be read in many ways :P
Just keeping it real Paul. I have the utmost respect for most things Jun. That oil pump and a set of Jun pistons were among the few survivors of that clutch debacle.
I would gladly reuse those slugs if i could find a tight enough block. They are standard bore and its tuff to find a block that will give us the correct piston to wall clearance.
Subsequent research led to Cosworth being the actual manufacturer of said pistons. Speaks plenty for Jun that they chose such a well respected outfit to outsource from.
Ash returns serve very close to the baseline but manages to keep the ball in play
hehe... the fact im working graveyards isn't helping... im seeing shit i probably wouldn't normally :P
Point taken, I was referring to engine components in general. As for the Jun pump it is one of the few survivors.
Ah i see, that is indeed good news then! Least it's clear for everyone (if anyone has been silly enough to be awake for nearly 24hrs like me) :D
yeah I read that the same as Ash... but I have no excuse hehe
I've had N1 pumps on a couple of engines that I've destroyed, pump was never at fault though... that said recently I've found myself short shifting at 8K to be careful I don't nudge the limiter
anyway that's hard luck Rezlo, sounds like its a killer setup, would be a wild ride... I would be checking that bottom end really carefully, fingers crossed for you
some people pay good money to see sh1t that ain't there and stay awake for days...lol...you however are making money from doing it so don't be a sook.
And as for you dirt man, Get your stick out of our pot. Go brew up your own concoction to stir.
you can bitch slap me next week when i come up to sunny QLD
my advice is buy some reimax gears for the pump you have. should be cheaper than any of the other options listed and they are good. very good. they have the runs on the board as far as I'm concerned..
http://www.reimax.com/pages/products/lower-area/index.html
I hear a rumor you were going to be at the bank tomorrow night.... Not true??
I like this idea.
Have a chat to Powertune in NSW about their RB26 oil pump gear sets. Made out of somethin crazy like P20 tool steel or somethin and the same size as a JUN gear set and they can machine the stock housing to suit.
I had an N1 pump fail <2000km old
Had new gears machine, apparently by Powertune - fingers crossed
Brisbane VL guru's JW Auto are producing an external kit we are helping them design. After problems getting the last supplier to move on these JW is keen to produce a bolt on kit for us. These kits will unfortunately for some require the removal of air-con but will utilise a modified STD pump housing making them a truely 'bolt on' kit. Very easy for someone with basic mechanical skills to install and will come with ATI balancer, modified pump housing, Peterson single stage pump, CNC'd adjustable pump bracket, Gilmer drive pulley's, anodised fittings and braided lines. They wont be cheap but they will be the best 'wet' sump set-up for RB's.
Once JW provide a sample kit for us we will make them available for limited release via a group buy.
listen to paul (dirtgarage) - i spoke to my tuner about this exact subject & it was simply explained it to me like this:
"the n1 pump has a sintered steel gear which is more likely to shatter under load whereas the nitto pump has a billet gear which literally has chewed up bits of a cast iron block in a recent engine failure"...need i say anymore :banana:
I called Powertune and they dont know about/sell these gears?
who did you speak to? and rough cost?
Thanks
Speak to Dan at ERD (SAU user elite32) - he is manufacturing the same gears now
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
