what's involved in doing a pump r and r in an R32 GTR with the engine in? doable within reason? those reimax gears look the goods.
you wouldn't do it...seriously, pulling the donk and doing it properly is a piece of cake. Id hate to see your anguish after seeing the sump leaking after trying to do it in the car only to go through the process again to try and fix leaking again.
Shanef ,can you elaborate on the powertune gears? are these sh1t ?
I wouldnt say they are shit, they are however made of a low grade material. They have a nice CNC machined finished aswell.
Saying that, in my view they can be improved upon in many ways :D.
too late shane, whats the reason behind that though?
I threw the stock on in the bin, shit :D
they are a saw tooth gear design...not a gerotor like other RB pumps. Saw tooth pumps are less prone to breaking due to harmonic vibration.
Hey Paul, i was almost set on getting a Tomei pump for my 2530 , there like high $1600's delivered (well they were 2 days ago, now 1750.... but the dollar is set to climb apparently.)
Do you seriously reccomend a Nitto over one of these ? If so what can you do one for ?
Gary
Wow a lot more response than I thought,
I can see there is a lot of banter about N1, I agree any pump will fail due to serious abuse, but how often do you hear of any Greddy, Jun, Tomei, Nismo etc pumps just randomly failing even when not abused? Before I rebuilt the RB25 it had 6 times more abuse at similar and higher RPM than this N1 and the stock pump held just fine even with the crap 1/4 depth pump drive.
I am surprised no one has commented on the Nismo pump considering it is in the middle of the price range.
I am thinking about doing some testing on the materials used in as many of the pumps I can fidn, does anyone have any old parts of inner and/or outer ring's they would like to mail me (only need 10-15mm of each each), get a good profile of all the different pumps?
Gary
Reslo bought, or is buying the last one from the group buy...around $500 cheaper than the Tomei pump. The Nitto gears are designed and manufactured in Germany and are made from superior material than any other OEM style pump. If Reslo pulls out of the sale the last one is yours, if not ill contact the group buy supplier to see if they will do another lot of 5 pumps at the reduced price.
Edited by DiRTgarage
fark me, i took the cover off to have a look as well and being a noob though the saw design looked pretty rubbish
might go cry myself to sleep
back on topic
same design the tomei pump is based on, hence its awesomeness
Reslo bought, or is buying the last one from the group buy...around $500 cheaper than the Tomei pump. The Nitto gears are designed and manufactured in Germany and are made from superior material than any other OEM style pump. If Reslo pulls out of the sale the last one is your, if not ill contact the group buy supplier to see if they will do another lot of 5 pumps at the reduced price.
why do they need to be made in Germany? Its not like there arent any machines here in australia that can't do the job. You don't even use a bloody conventional CNC to do them properly.
plus all (from what i've seen) aftermarket pump housings are shitty cast housings, f**k me they'd only cost ~600 to make
or is Germany code for Taiwan?
Just awaiting shipping prices :D
reZlo
Ok, thanks Paul, let me know.
Just out of curiosity, assuming money wasn't a consideration, would you pick the tomei over any other ?
So the Tomei uses a Saw tooth design ? Anyone got any nice pics to show of one open ?
Also for the guru's..... whats the disadvantage of the saw tooth design ?? I ask as i assume the newer gerotor design is better somehow since nissan swapped to them. (from a factory motor point of view not racing)
Gary
Gary
Saw tooth or not ive seen what a Nitto pump is capable of...im not gambling on other brands when i know i don't need to. Id buy a Nitto over a Tomei.
Gerotor pumps are more efficient in working, but easily damaged from foreign material running through them, whilst gear pumps (saw tooth types) can easily pass crap and not get damaged (too badly)....they are more forgiving and genereally more reliable.
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
