well....that video looks crazy but in fact those g forces are what we are putting through these motors on the race track. and with a wet sump
its a great example of how extreme things really are.
RB N1 vs stock SR20,
both outer pump gears are identical in OD,
pump drive on the SR20 is about 3mm smaller than the RB, which means the actual inner pump gear on the SR20 is 3mm more beefy, probably why it doesnt crack...
SR20 has a 2mm narrower gear due to reduced oil volume needed.
And its got nothing to do with power, there are RB N1's failing 150-200wkw earlier than SR20's running stock pumps.
argh... that sucks about the N1 oil pump. I'm also running one on my GTR, which I think I'll change to a Nitto pump at some point, hopefully soon.
PS: Hi! from a fellow South African :D
If we only had the factory dry sump with this kind of testing...
what a great find - thanks for sharing!
2 q's:
- does the 09 porsche have a dry sump from factory or is this a race spec engine?
- how do they simulate the torque in those gear changes? it sounds like its running through each gear around a track (some type of dyno?)
awesome stuff :down:
2 q's:
Factory dry sump as most 911's have been
It is on a moving engine dyno
PS: Hi! from a fellow South African ;)
Where from?
My advise, change the pump before it breaks... seems to be more a case of "when" rather than "if".
2 q's:
awesome stuff :D
Yep factory dry sump on all ...
And the dyno loads the engine accordingly to simulate the loads/throttle that would be applied when in that particular gear around the circuit...& the fact that they can couple it to simulate cornering g forces as well is really cool.
Im also in two minds what to do with the N1 pump that is on my engine..not exactly confidence inspiring.
I think it should be renamed the russian roulette pump ;)
so we need someone to machine up some splined collars and gears for the pump :D
I'm actually at my machinist tomorrow picking up something anyway so i'll discuss it with him and get back with a possible outcome.
I was just re-reading some mags last night before i went to bed, and i noticed in the article on the "700 Hp GTS-T" Cola coloured with carbon bonnet in HPI 102 . At the starts it stated he fitted an N1 oil pump. Just at the end of the article, it says, "As we went to press, we learnt ..blah blah blah ... the oil pump broke in two places !"
Thought id share
Makes you wonder if something has changed in there material composition or tolerances or something. Has anyone who has been racing or building with N1's for years seen this years ago, or was there a time they seemed to be ok...
I think Greg said he used to use them until the recent failure ?? Makes you ask whats changed..??
Gary
I was under the impression that the early N1 pumps were fine (I believe mine is an early one), but it was rumoured that a couple of years ago production moved somewhere else and then lots of breakages started to happen?*
*may or may not be true
On the gears changing, I know there are some companies in China who are producing a lot of powdered metal parts, maybe Nissan started sourcing them from there? Whatever the case, I won't use them any more, or if someone wants to use one, it's their problem if it breaks.
I'm getting some info on the gear splining, should have some news in the next week or so about a billet spline drive gear set to fit the standard housing. I've also been cadding up a new front housing that uses an external pump, probably a single stage petersen one but doesn't get in the way of the accessory drives or anything else.
And Shane, what are you up to now.... i thought you sold all your stuff !
I'm selling up but that doesn't mean i have to stop developing parts :)
A bit of conflict of interest here but i'll update this post when greg gets back to me.
i like that, sounds promising. i'm happy with wet sump so long as the dam oil pump wont break!!! billet splined would be well worth any cost...
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
