Don't understand why people won't spend an extra $500-$700 on a better pump rather than play oil pump roulette... I will build mine to last the hard time I want to give it not baby it because I am too much of a tight ass.
ive smashed an n1 pump - now using nitto!
n1 is like that movie fatal attraction
No pump is safe from being destroyed if you limiter bash. Even Tomei's can be killed.
spending more is not necessarily 100% fail proof due to the pump design!
Did not say it was 100% fail proof, but given the choice I do not see why anyone would go with an N1 considering their record. I would spend more (on a Nitto, Tomei, etc) to know that is was a 100% improvement over an N1.
And if you want to (or be safe from accidental) limiter bashing then go an external for slightly more coin.
fuel cut explains the massive flames that gtr's shoot out on the limiter - most gtr's u will see in japan run this way. so my guess is that fuel cut is acceptable but not sure if its better or worse than ignition cut?
  • Nope 1
errr....might want to re-read what you just wrote Marko.
No fuel = no flames
  • Like 1
Its been mentioned before so many times. But the clearance on the drive and pump is a problem in my opinion.
If you take a N1 pump gear and slide it over a R34 crank ir jun collar, there is .006" clearance each side. .012 total! It rattles like crazy when limiter is being hit. As mentioned just above. when limiter is reached the crank has to slow down before fuel is added to complete the combustion cycle. A loose crank/collar to pump is just smashing in there when its on the limiter. Every N1 pump or most pumps that have failed, crack right at the flat corner and then the rest is history.
Now i know im not the only person that figured this out. I have made new collars with .001" clearance each flat for a total of .002". Slips right on no problem but it doesnt have that loose fit like all the nissan cranks and Jun collars out there. i've gone through about 20 of them now with N1 pumps selling them to friends and stuff and not one problem yet.
Just look at this picture. Every crank you pull out looks like this. Its just retarded! the drive only has 3/16" contact. Crazy!
Ive seen almost every brand of pump brake. Looked at all the pictures people post up after and I always see the crank look like that.
Collar I made up. Just gotta flont the piece, lol. Im not saying there isn't a design flaw, but there is this one issue that is easily taken care of.
Would spark cut be easier on an oil pump than fuel cut?
same shit for an oil pump, engine is still stopping and starting in the same way. the only difference would be between different ecu's, for example, a stocker rb30e ecu cuts fuel to all cylinders when you hit 6200 and then cuts back in at around ~5800. a power fc randomly cuts cylinders to hold the motor at the set rev limit.
  • Like 1
No doubt it's a shit design...
Good on you for trying to overcome the issue!
My beef has always been the fact that there is only 2 surfaces driving the pump, why not have more so there is less stress on the surfaces?!?
It's a real pity the guy who was trying to make the splined gears got ripped off by his machinist :/
That may be my next step. Your totally right on tho!
What happened to the guy that was designing the splined gears? Machine work in Canada is relatively cheap. I got a few guys I use and its very reasonable. I'd like to see what this other guy ended up with as a design. Did he make new gears completely or just the inner gear and drive for the crank?
I think there has to be a cheap solution for everyone. Or we could all go dry and call it a day. none of this inbetween stuff ($1500 for same design pump)
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
