Furthermore everyone should dry sump without question regardless of their needs or requirement as risk is not good.
problem with a dry sump setup is cost - for something decent you are looking at up to 7k
Ofcourse every oil pump is a risk. But we dont log on here to see every couple of months a comment about how my std oil pump just killed my motor, or my (insert brand name here) pump just shat itself...its always the N1 pumps that come up either on here, or in conversation/passing comment or someone at the track blows one up.
Its obvious the risk is higher using one, its virtually the point of this thread. Hearing one bad story should be enough. It was for me, except ive been exposed to multiple, whether on here or at the track. Im sure alot of people who have seen this thread will agree with myself and the others who share the same opinion about N1 pumps.
Its simple. You get whatever puts your mind at ease and fits in with your budget.
Dry sumps all round for everybody.....hooray :P
Edited by r33_racer
guys loosing sleep over the pumps go and buy the reinik (edit reimax... still getting used to name change) gears. they are very highly regarded in japan and folks smarter than me have been using them in aus with great success. they may not be jumping up and down telling everyone about it, but the price is right, they have the research behind them to back up their product and that should be the end of your oil pump problems.
If you're spending 7k on a dry sump setup you're spending too much.
nitto would be my choice, crd has been exposed to all oil pumps available and i trust the opinion of a man who started modifying gtr's when we were all still playing with matchbox cars and smashing them with hammers to simulate an accident
dry sump for me is overkill for a weekend warrior
Where are these available from?
I still think the best fix would be a splined collar/gear.
Cheapest Reimax gear set i can find so far is 670 au + del. through Greenline.
http://www.greenline.jp/catalogue/bproduct...&fromlink=1
It probably is best value for $$$ if you are planning on taking your engine to pieces or in the build stage.
Edited by Alf
Lookin forward to these new gears!
would they work on a stock pump? or does the stock pump not provide enough pressure?
say compared to a n1?
They can be made to suit a stock pump, but these first ones are going to be for the N1 pump.
Pump selection should be left upto the engine builder.
I to had a n1 let go on e and decided to go external pump
i have had no probles since and thrash it of limeter all day at the track and the cost was not to bad
$1000 for peterson single stage pump
$200 for mandrel for the crank
$200 for speedflow fittings
and 1 day in the gargae making a bracket for the pump
This is the way to go imo
That's under valuing it a bit to say the least. Add another $600 and ur closer to the mark you woulda spent. (not saying u didnt spend that but just adding this so everyone doesn't jump to the conclusion it only costs $1400 to do a complete external oil pump setup)
Shane, are there different thickness N1 gears? I remember getting confused when I last looked at the Reimax ones
There are indeed my good friend. So what we'll have to do is the person after a set will have to specify what thickness gears they are after.
Group buy thread here - http://www.skylinesaustralia.com/forums/Sp...ts-t285926.html
Cool, I'll try get my oil pump off this weekend and confirm thickness.
FWIW, here are some parts numbers that I came up with and pricing for an external oil pump kit. I only really needed to find someone to make a bracket for the pump itself, most of the parts are there minus the hosing and belt. Might be a couple of extra fittings required depending on where / how you wanted to mount it.
Some of the prices may have changed since I did it (about 4 months ago)
JWAuto are doing CNC brackets...their work is incredible...the same CNC machinist 888 Racing use. Top shelf stuff. They are doing the brackets in a kit only though...im doing a group buy on them as soon as they are ready. I saw one of their VL CNC'd rocker covers to suit single cam engines running roller rockers...porno! Ill see if i can get a pic.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
