hey they sponsor my racecar so i mention them where i can...lol
did somebody say Vi-PEC ? :blink:
Haha, forgot about that one.
Did you say Vi-PEC, I have a Vi-PEC too! We should all get Vi-PEC's...
Vi-PEC!
Edited by bigmikespec
Were the Group A GTRs from the early 90's a dry sump or externally oiled?
interesting question - anyone have the answer?
i question the reliability of an external oil pump although i might be on the wrong page :blink: ...what are the points of failure other than the 1st & obvious being the belt drive? i'd guess this belt could randomly snap just like any other belt - my thoughts is that its great for circuit where the car is highly maintained but for the street...would it be a feasible option?
paul, you have a nitto pump right & its fine for your monstrous setup?
the likes of crd dont recommend external pump (unless it is an extreme application)
I run a JUN pump on mine...ive been smashing it off the limiter for a few years and now the anti-lag.
I wont be running an OEM style pump on my engine when i pull it for a freshen...external is the way to go. For all my tough street builds i exclusively use Nitto...the best.
Edited by DiRTgarage
i question the reliability of an external oil pump although i might be on the wrong page :D ...what are the points of failure other than the 1st & obvious being the belt drive? i'd guess this belt could randomly snap just like any other belt - my thoughts is that its great for circuit where the car is highly maintained but for the street...would it be a feasible option?
If they are setup properly in the first instance there is no plausable reason why they should fail. And by setup properly i mean having the correct alignment in both planes, belt guides on BOTH pulleys & correct belt tention.
The only ways i can see that it could fail other than incorrect setup would be:
- teeth wear (same as ur cam gears though, how fast do they wear? not very fast at all)
- belt damage i.e little snick from debris hitting it etc
- bearing material passing through the pump scratching both the pump housing & gear sets (you should be running a pre-pump filter anyway)
The only downsides for running an external pump in a street based car are:
- Required to run thermo fan setup as pulley on front of balancer hits clutch fan
- Little fiddley to setup correctly
Other than that its full of win :D
P.S You should be maintaining your car properly anyway, if you let maintenance or regular checks lapse, thats when a big failure is most likely to happen.
My purchased new from nissan N1 failed 2 weeks ago, nailed 2nd, hit the limiter & thought I heard something..... checked my oil pressure to notice it was down to about 15psi & dropping to zero not long after. shut it straight off so hopefully not to much damage. been on my 26/30 making 455rwhp for about 3k, all balanced with Ati balancer, pro engines collar.
pulled the pump off to find gears smashed to pieces, minimal damage to the crank collar. Ill never use an N1 pump again, massive waste of money to buy and almost cost me a fortune in f@#ked motor. think I was lucky to catch it before massive engine failure.
The question now is what pump. I have an RB25 pump, anyone had any problems with them breaking? or does an RB30et toothed oil pump perform good enough to support twin cam setup? Thoughts?
Nitto pump is the only OEM style pump ill use or recommend using.
I will have a dry sump kit available in a week or so just waiting on the last few bits to be anodised. The kit has been tested on two 500+HP GTR's for the last 18 months without a problem. For anyone interested PM me for details.
Other than the gear set's in the N1's are there any other problems/design faults to be aware of? eg if/when I run a splined collar and gear set with an oem N1 pump, will somthing else fail?
NB: In the states, N1 pumps sell for as little as 192USD + shipping. I bought 3!!!
that's a bit worrying.
splines are the best option imo without opting for a dry sump. using a splined system you can use a material that does not have to be as tough as the OEM system (which is very very tough but also brittle).
Ideal gears will have the plastic deformation limit quite far from the UTS. As obviously the closer the plastic limit to the UTS the more brittle it is. Personally id rather the gears round themself off than sheer in to pieces.
what material are these splines/gears going to be made off?
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
    • Yeah pretty sure they are m4, but best to check, and perhaps use new hardware Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
