Marko, dont mind if I answer your question do you?
Nitriding is competely different to cryogenic freezing. Nitriding is a process where a component has nitrogen introduced into the metal surface (under high temps). Makes the surface super hard but you still retain the metallurgical properties of the orginal metal beneath the nitrided surface.
awaits splined collars + gears. preferably to fit standard GTR pumps since it's imo a waste of money buying an N1 to rip out the gears anyway.
Yeh that's something greg said the other day aswell. A std pump will be more than capable to supply enough oil at the right pressure.
that's a bit worrying.
splines are the best option imo without opting for a dry sump. using a splined system you can use a material that does not have to be as tough as the OEM system (which is very very tough but also brittle).
Ideal gears will have the plastic deformation limit quite far from the UTS. As obviously the closer the plastic limit to the UTS the more brittle it is. Personally id rather the gears round themself off than sheer in to pieces.
what material are these splines/gears going to be made off?
4140 as per below :)
Apparently.. "The collar will be made from 4340 and the gears made from 4140. Both will be nitrided and isotropically treated."
Getting all in 4140 so we can wire-cut the splines out of 1 piece.
Nitriding will penetrate the surface between 4-6thou, so it wont affect the structural strength or make them 'brittle'.
Shane,
Have you had any issues with machined parts moving after you get them nitrided?
PS: wire cutting is f**king sick!!!!!
I cant say i have mate, but these will get a final surface grind after they are treated and a double check before i'm happy to say they're good to go.
It certainly is! :)
FYI: I've had a few issues with some things moving post nitriding. Final grind post treatment is the go! :) (just dont break through the lovely super hard surface).
Generally things must be surface ground after nitriding due to the surface expanding unevenly. That is the gas can be absorbed at different rates in the material. However given that these are gears and not a bearing surface (like a crank) it should not matter as much.
Cryogenic treatment is excellent in making material stronger. So you have a good mix. Nitriding does nothing for strength but makes the surface very tough and cryogenics does nothing for toughness but adds strength (re-aligns the grains correctly i believe)
potentially Allows obviously a more plyable material to be used which IMO is a good thing when it comes to gears.
GTR standard pumps would be the go imo! Looking forward to these, hopefully a cheaper cure to this problem.
PS: How many splines are there going to be (sorry if this was mentioned earlier also) As obviously the more splines (think 10 splines per 25mm) the larger the surface area but with that comes smaller splines which requires smaller tolerances which may not be suited for the heat expansion that these gears will come under during the operation of an engine. Looking at the Supra design posted earlier in this thread would be a good way to go, not very many splines but it's clearly a tried and proven logic.
PS: If possible 4340 is the superior material compared to 4140 but obviously it does come down to the manufacturing processes s available.
Edited by GT-RZ
Excellent thread this one!
Gotta be one of the best ones in a long time, a problem came up and with the bouncing around of ideas, a possible but more then likely probable solution has been achieved and not only that, its actually going ahead rather then just talk.
Kudos to Greg, Shane and everyone else who chipped in.
Need more informative and potential RB development threads like this rather then same old same old.
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
