If i was over reading the play i'd be saying that you said Tomei pumps are shit and you shouldn't buy them, being you've also kill one :D
They are not shit, there is only select evidence here and there, perhaps as paul said the material has changed, who knows what goes on in a manufacturing plant during tougher times.
Dude I dont know where you get your info But i reccomend you find a new source. The current one is making you look like an asshat.
The only oil pump I have ever purchased and or owned other than the original stocker is a Jun. This pump has survived 2 engine failures. One when the clutch ripped the engine and drivetrain apart and the other when I shat a turbo through the engine.
The oil pump has been apart and inspected and crack tested on both occasions and is now happily singing away on track duty at over 500 rwhp.
The only oil pump I have ever purchased and or owned other than the original stocker is a Jun. This pump has survived 2 engine failures. One when the cluth ripped the engine and drivetrain apart and the other when I shat a turbo through the engine.
that post did 2 things...made me lol and then gave me a warm fuzzy feeling that my JUN pump may live longer than i expect it too. Nice one Fox.
Edited by DiRTgarage
Well i just went by your post
Check out the price of the Jun pump while you're at it. A fair bit less than the tomei item and I have broken about everything except the Jun oil pump to date. :D
Can be read in many ways :P
Just keeping it real Paul. I have the utmost respect for most things Jun. That oil pump and a set of Jun pistons were among the few survivors of that clutch debacle.
I would gladly reuse those slugs if i could find a tight enough block. They are standard bore and its tuff to find a block that will give us the correct piston to wall clearance.
Subsequent research led to Cosworth being the actual manufacturer of said pistons. Speaks plenty for Jun that they chose such a well respected outfit to outsource from.
Ash returns serve very close to the baseline but manages to keep the ball in play
hehe... the fact im working graveyards isn't helping... im seeing shit i probably wouldn't normally :P
Point taken, I was referring to engine components in general. As for the Jun pump it is one of the few survivors.
Ah i see, that is indeed good news then! Least it's clear for everyone (if anyone has been silly enough to be awake for nearly 24hrs like me) :D
yeah I read that the same as Ash... but I have no excuse hehe
I've had N1 pumps on a couple of engines that I've destroyed, pump was never at fault though... that said recently I've found myself short shifting at 8K to be careful I don't nudge the limiter
anyway that's hard luck Rezlo, sounds like its a killer setup, would be a wild ride... I would be checking that bottom end really carefully, fingers crossed for you
some people pay good money to see sh1t that ain't there and stay awake for days...lol...you however are making money from doing it so don't be a sook.
And as for you dirt man, Get your stick out of our pot. Go brew up your own concoction to stir.
you can bitch slap me next week when i come up to sunny QLD
my advice is buy some reimax gears for the pump you have. should be cheaper than any of the other options listed and they are good. very good. they have the runs on the board as far as I'm concerned..
http://www.reimax.com/pages/products/lower-area/index.html
I hear a rumor you were going to be at the bank tomorrow night.... Not true??
I like this idea.
Have a chat to Powertune in NSW about their RB26 oil pump gear sets. Made out of somethin crazy like P20 tool steel or somethin and the same size as a JUN gear set and they can machine the stock housing to suit.
I had an N1 pump fail <2000km old
Had new gears machine, apparently by Powertune - fingers crossed
Brisbane VL guru's JW Auto are producing an external kit we are helping them design. After problems getting the last supplier to move on these JW is keen to produce a bolt on kit for us. These kits will unfortunately for some require the removal of air-con but will utilise a modified STD pump housing making them a truely 'bolt on' kit. Very easy for someone with basic mechanical skills to install and will come with ATI balancer, modified pump housing, Peterson single stage pump, CNC'd adjustable pump bracket, Gilmer drive pulley's, anodised fittings and braided lines. They wont be cheap but they will be the best 'wet' sump set-up for RB's.
Once JW provide a sample kit for us we will make them available for limited release via a group buy.
listen to paul (dirtgarage) - i spoke to my tuner about this exact subject & it was simply explained it to me like this:
"the n1 pump has a sintered steel gear which is more likely to shatter under load whereas the nitto pump has a billet gear which literally has chewed up bits of a cast iron block in a recent engine failure"...need i say anymore :banana:
I called Powertune and they dont know about/sell these gears?
who did you speak to? and rough cost?
Thanks
Speak to Dan at ERD (SAU user elite32) - he is manufacturing the same gears now
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
