i received an email today from nitto sales re the launch of their new site, good work jim and theo...its been a long time waiting
prob cost more than man on the moon for a 1-off too :blink:
I coudnt imagine it costing more than a new oil pump. Personally i think its rediculous to have to spend over $1000 for a decent oil pump. Here in the states i dont any stock style oil pump costing anywhere near $1000 but the RB ones. Its a F'ing rip off.
Is it possible to take the N1 Pump apart and take the old gear to a machine shop and have a new stronger gear made?
Yeah you could. (Machine work in the states is alot cheaper than in Aus.... and if he drives a 240sx, he's american)
I thought it was done just outside Area 51. Haha
Ha ha ha ha ha ahh a.... it was shot in a sound studio in Navada. Apparently in the movie you can see the light from a door being opened off stage.
  • 1 month later...
Has anyone tried to use the replacement billet gear sets for N1 pump ? Made by JPC Performance in AU. http://www.jpc.com.au/products_rb30.php
Could that be a sollution to the problem ?
Edited by RB26SX
i didnt read every letter of all the previous posts, however, I have a FJ20 engine in my ride which dont have the best oil pump in the world from factory in them either. When i built my engine i used a BDG external oil pump. Its a single stage belt driven unit with a mounting bracket off the side of the engine to mount it and a plate with a spline welded onto it bolted to the front of the harmonic balancer. We machined off the 3rd pulley from the balancer and bolted the plate there in its place. The pump was $960 and then once the internal pump was deleted, it was a matter of tapping a fitting into the block and making up a pickup in the sump the suit. Base pressure and peak pressure can be set very easily via an allen key adjuster and spring selection.
Maybe worth considering... just a thought.
Please ignore the control arm chop. It has been boxed in and strengthened since these pics.
Just throwing my own little bit of fuel on the fire. I happened to have a N1 pump sitting around waiting to go back on my RB24 when it's done. I also happened to have a RB20 crank with a JUN collar installed that came out of my engine before it went to the builder. Took a little vid just to show the amount of play between the two. I also mic'd the two and came up with 0.22mm of clearance between the flats. Seems a bit excessive to me. I personally don't think it's a material issue as much as a design issue. And it's not just a pump design issue but, an entire oiling system design issue. I would bet that while not all of the N1 failures happen during heavy acceleration or cornering that the initial damage that leads to the failures did. I think that any kind of cavitation in the pump do to the oil sloshing to the back or side of the pan could cause extra resistance on the outside gear or even momentary seizure. This coupled with a loose fitting drive I would think would be enough to break the gears. I also think that has something to do with why Sydneykid prolly hasn't seen the failures that most have. If you do everything to keep the sump from ever sucking air this isn't an issue at all. When my engine gets back I'll have to fit the N1 drive gear to the R33 crank that's in it now and see if there's a difference. And just so it's clear, I'm not championing any pump or pump fix here. I'm just suggesting a cause to the problem.
I've got two sets of the JPC steel gears here for an RB30 and RB25/30 I'm currently doing. I can snap some photos if you're interested. They fit an N1 housing, not a standard 25/26 pump. I've only had one in well over 50 N1 pumps break but that's one too many and the steel gears are cheap insurance.
This excessive clearance is something I was alluding to several pages ago.
I'm still waiting on my splined gears but if that doesn't come through, as opposed to using the collar that I have sitting here, I am thinking of having the snout built up then machined back to suit my specific N1 gears.
bubba - that is a lot of play, cant belive that!
i just wonder whether this clearance is required though for heat expansion...greg, what are your thoughts on this? do you recall how much play my pump has with the customer collar you made for it?
i also noticed that the clearance between pump gear and crank was high...
what i dont understand is why nissan use two flat surfaces to drive the pump so all the force is put on two small areas. surely a hexagonal shape or similar would have worked much more effectively
If heat expansion was an issue wouldn't the timing gear be prone to failure when the engine reached operating temperature?
it was $960 for the pump and then the price of a custom sump, mine was around $300 from memory as the engine builder did the whole engine including the sump. Then some braided line and a mounting bracket, the belt and modification to the crank snout. Around 2k in total i think. I dont have much of an idea what a new aftermarket high flow internal pump costs for an RB, but i thought 2k for a big oil setup was pretty good.
G
They need clearance to allow for manufacturing tolerances where the centreline of the crank can be not quite concentric with the centreline of the pump gear, I made yours a little tighter Marko because I sat the pump on and checked where it was running before I made the collar. The clearance isn't a problem. The standard rb25/26 gears don't break and they run the same. SR20's, CA18's, Toyota 4AG's, Hondas and others run the same drive setup and rarely have problems. Nissan TB48 engines have a similar problem when they're pushed. I think it's just down to the material used. Powdered metal is used for a lot of parts that are hard to machine cheaply, almost all oil pump gears are made the same way. To mill an N1 outer gear you'd need to use a <2mm diameter cutter which just isn't workable for that type of job.
I don't know why Nissan made the N1 pump with a smaller diameter outer gear which makes everything a little thinner and easier to break. I just fitted a set of the JPC gears to an N1 housing and they are good, same side clearance as factory and about .001" more clearance between the gears. The engine is from a hillclimb/circuit car still running the hydraulic tappets so I didn't want to go for a bigger pump.
Hey there Greg.
Interesting that you wrote this as it brings up a question I've wanted to ask. I am about to buy a Tomei Pump for 'insurance' that my current N1 Pump doesn't break - however I wonder what are the disadvantages (if any) of having the larger pump besides its price.
I have a winged 9Litre Performance Metalcraft sump. People talk about the Tomei 'running the sump dry' but this makes no sense to me unless they are running massive pressure... if the pressure is adjusted on Tomei to a similar pressure of the N1, then (given the same motor) the flow should be near identical should it not? ie the Tomei will bypass all the extra flow straight back to the sump? And if so, is this a problem?
Long ago I looked at replacing the N1 gears with the Reimax ones. The reason I bought the N1 in the first place was because the RB26 already seems to suffer from too much oil going to the head (so everyone puts restrictors in). So there didn't seem to be any point going to the higher volume pumps given the clearances that are run.
So is the only real reason to put a Tomei in for the strength of its gears? And for the fact that is has this '3 gear' design which might be a little more forgiving on any crank wobble? Or is it actually "better" to run an N1 size pump with Reimax (or JPC etc) gears for strength.. Lets forget price for a moment, lets just say you could buy either for the same price:
1. Tomei with the pressure kept down (and hence less oil pumped to the head)
2. N1 with very strong gears.
(guys this is not a N1 vs Tomei or Nitto or JUN question - just a question of High Pressure/Volume vs 'needs' of the engine I guess)
Thoughts?
Edited by R32 TT
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
