.....I can see there is a lot of banter about N1, I agree any pump will fail due to serious abuse, but how often do you hear of any Greddy, Jun, Tomei, Nismo etc pumps just randomly failing even when not abused...
Well this is the random old internet not some carefully researched study.
How many std oil pumps are there (90+%), how many failed, and what sort of life did the ones that fail have?
How many n1 oil pumps out there, how many failed? I bet it is 5% or less of motors out there
How many of the other aftermarket ones....1%???
How many people run dry sumps instead.....2%
I reckon its no surprise you don't hear of the other aftermarket ones breaking....there are stuff all of them out there, and not everyone likes admitting they have had a terminal problem with an expensive motor.....oil pump can easily cost more than the rest of the motor.
What's the bet the people that kill a first motor with std pump are more likely to be using the motor hard, and these people then go to n1 pumps, treat them harder than normal, and they break?
Or how many n1 pump failures are due to un-noticed bends in the crank from the first engine blow up that was not repaired or replaced? Or twisted block that was not tunnel bored?
Or how many n1 pump failures are due to crap running through them (this was my problem) due to some other issue in the motor?
Despite this thread going for pages, I bet less than 3-5 people have first hand experience with a broken n1 pump.
your right Duncan, but i'd say there may be a few more n1 pumps out there that people have just replaced on their stock motors as a cheap fix.
it is a fairly cheap thing to do to the motor, and often you'll get them on cars from japan without knowing it.
driving my car around for years i thought i had a n1 pump as i have nice pressure.. apon engine failure after boost abuse i found that it was infact a jun pump :D
A thought occured to me when looking at my crank collar.. what is the clearance between the collar and the oil pump drive? would it be better to have something machined to suit the specific oil pump you are going to use so as to get the best fit?
Is anybody going to address this question?
Someone else raised the same thing when asking whether it was only on the thrust side and could it be a clearance issue..
Ok, thanks Paul, let me know.
Just out of curiosity, assuming money wasn't a consideration, would you pick the tomei over any other ?
So the Tomei uses a Saw tooth design ? Anyone got any nice pics to show of one open ?
Also for the guru's..... whats the disadvantage of the saw tooth design ?? I ask as i assume the newer gerotor design is better somehow since nissan swapped to them. (from a factory motor point of view not racing)
Gary
hey gary - you should go straight to the horses mouth & speak to jim from crd about the nitto pump...he has had over 20 years experience with the gtr & has been exposed to countless pumps (n1, tomei, jun, stock). he will give you the low down in about 5min :D
I wonder how many guys using N1 pumps are using an N1 balancer too? according to the guys in japan that know their shit they always tell me if using N1 pump, switch to N1 balancer too.
As opposed to stock or aftermarket?
Phew.. got my 1000hp ATI balancer sitting here and was hoping I didn't have to turf it :P
Any thoughts on machining a collar to suit the exact oil pump you're going to use? what sort of clearance would one use?
Depends on expansion rates of crank and drive...if there would be any....but for a damper to crank snout, a .001 thou interference fit is ideal.
Internally, the better the fit the more contact area you have and obviously a more even distribution of load on the gear....would be good if someone had a collar and gear to measure so we can see whats what, then go from there.
Edited by r33_racer
I will have my engine apart very soon as new rods are going in and it's going to the machinist to be balanced. I have a collar to go in but when it's all apart I shall mic up the oil pump drive and the collar aswell as the stock drive on the crank and report back.
I'll also take some photos of the oil pump, it's one of the older N1 pumps.
Would be nice if a few people could mic up any oil pumps they have lying around so we can see what sort of tolerances the factory is machining to.
Edited by bubba
I have found around 20 cases already all apearing to be "for no particular reason" over a few other international GTR forums.
I think material testing will tell a lot.
turf it...turf it...into an express post bag and send it to my place. ill send you a 600hp one and 4 Edith Cowan's to tempt you.
when ur buying ur fuel system from www.summitracing.com just throw in the 1000p balancer too paul! :P
Hah! dreaming ;)
I got mine from summitracing.. actually got 3x of them and some autometer gauges then had to pay customs $440 to get my box of bits! :(
So in the end I don't think I actually saved any money over buying them locally :)
Edited by bubba
Hah! dreaming :P
I got mine from summitracing.. actually got 3x of them and some autometer gauges then had to pay customs $440 to get my box of bits! :down:
So in the end I don't think I actually saved any money over buying them locally :/
yeh thats the only problem, uve gotta keep the single order below 1k or u get assed raped with the stupid taxes, and only because they are automotive parts we can't claim free trading (f**k you government)
Yeah I know about the import duties but we've managed to sneak through many times before without getting stung.. or do we have an agreement with Japan?
2.5k order from Japan (2-way + other bits) - not stung.
3.5k turbos from Japan - not stung.
HKS 2.8 kit from Japan - not stung.
2k order from US - stung :down:
Anyway, back on topic.. should hopefully have my engine apart this weekend or early next week, will inspect N1 pump and report back accordingly.
Edited by bubba
before we get back on topic...
anything coming from summit is automatically picked out at customs, i rang the head of customs finding out why we get stung and they said in conversation that anything from summit is picked out straight away. their boxes stand out pretty well so its hard to miss them :/
k, back to it...
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
