Yes you can, however you will need to go through a blueslip check, and ensure you have ALL the documentation from compliance, reg in Vic etc etc.
Any paperwork that has anything to do with teh car get a hold of it. Import docs, everything.
I bought a V35 in QLD and when it came to register it in NSW it took about 3 attempts. Everytime i went to the RTA there was another document they needed. I was just lucky that the owner i bought it off had everything in a nice neat folder for me.
Of course it will need to be close to stock to pass the blueslip as well.
Hey Daniel
The docs that i got included (off the top of my head)
From your first post I'm assuming they will register it in VIC first? I would tell them to def do this if you can. Might make it easier. Also you will def need to go through the RTA Inspection station as everyone of my imports have been "randomly" selected to be inspected. the bad part is that it's usually 2 weeks after you attempt to register it and they won't let you book in advance.
Import Approval
Compliance paperwork - this is a few pages long from memory
Vic registration certificate
Vic pink/blue slip or whatever their equivalent is
Receipt from seller
Transfer of Registration
Try this link, and maybe even pop into your local RTA and have a chat to them. One thing i found is that different RTA's have different levels of "we hate you" when it comes to imports :-)
http://www.rta.nsw.gov.au/registration/get...tevehicles.html
I bought my car in Victoria and transferred the rego to NSW.
You need all the documents from Victoria.
When you get the car to NSW you need to get a pink slip done, if it doesn't pass the pink slip then the mechanic will give you a white slip listing what needs to be fixed. After you get the white slip cleared you take it back to the mechanic to get the pink slip.
Then you need to get a green slip, get some qutoes from some insurance companies to find the best deal...i ended up getting myne from AAMI.
After you get the pink and green slip take the car to the RTA and book a time for the vehicle to be inspected for a blue slip. I cleared the blue slip inspection the first go so I am not sure what happens if you fail that part. After they give you the papers just take it into the RTA and get the rego all done and your ready to go.
It's been nearly a year since my car has been regoed in NSW so I am not 100% but I am pretty sure that I covered everything.
Good luck with it brother, should be able to get through it easily if the car is stock and clean :banana:
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
