Parting out a R32 GT-R. If there is somthing u are chasing thats not listed just pm/call me to see if i have it. 0437 838 032
All Items located in Cairns, QLD.
Aftermarket parts
All aftermarket parts are brand new still in there packaging unless stated otherwise.
Tomei Gasket kit 87mm $800
CP pistons/Eagle rods $1400
Jun oil pump $1200
jun crank collar $180
tomei type B cams $800
tomei type B valve springs $750
Heater Hose Kit $150
cusco catch can $80
ARP main studs $300
ARP head studs $500
tomei cam cap studs $200
PWR radiator 57mm (used) $800
tomei cam gears $300
MSD dis 4 (used) $250
Accel Coils x3 $150
trust dual gauge pod $100
greddy turbo timer (used) $50
c's short shifter (used) $350
whiteline adjustable swaybars $500
D-project adjustable traction arms (rear) $250
D-project adjustable camber arms (rear) $250
pineapples $120
bilstein shocks/ebaich springs (used) $1000
rear cradle bushes $125
lower rear control arm bushes $100
nismo braided brake lines (used) $200
Ross Balancer $500
cam cover baffels $300
Hicas lock bar (used) $40
Stock Parts
All stock parts are off a 1990 R32 GT-R (gun metal grey) with 135000 kms unless stated otherwise.
Engine Block + Cradle $500
Rods $100
Pistons $100
Head w bent valves $700
Good 26 Head $1200
head studs $100
Front bar $50
front guards $350
bonnet $500
head lights $400
tail lights $300
indercators $100
stock sway bars $150
crank $100
oil pump $50
water pump $20
front seats $400
steering wheel $70
air vents $25ea
diff $400
sand blasted/primered suspension parts (rear cradle $150, front cradle $150, rear lower arms $100, rear cradle braces$70, Front uprights $200
steering rack $150
spoiler $300
stock turbo's $200
shell $1000
boot lid $300
gearbox $500
tail shaft $300
front brake calipers $300
front brake rotors $20
Rear Brake calipers $150
Rear Brake rotors $20
front hubs $300
rear hubs $300
computer $100
front drive shafts $150
front prop shaft $100
T.P.S $75
Engine cover set $250
Engine Loom $100
Front reo Bar $100
Rear Bar $150
I also have a bare shell the will be sold to the highest bidder in the next 2-3 weeks pm/call me with your offer. pics will be uploaded asap
Edited by R32 GT-R
Hi Mate,
Could you PM a price for
the head, block, plenums throttle body, sump, wiring, iginitor, crank angle sensor.
and engine mounts.
pretty much im after everything to build a motor may even take the pistons, rods and
gasket kit of you for teh right price.
Cheers
Garth
I cant pm because of post count but would you be able to pm me some more details about the shell please, including a ballpark figure (as a rolling shell) , weather it can be regoed or not, thanks
Mark
Edited by mr m00se
Yeh sorry guys I have been up cape trib with no contact to the outside world. I've set aside the next 3 hrs to reply to your pm's etc. Can only reply to a pm every 5 mins cos of the forum restrictions..... very annoying admins!!! they will all be replied to in order.
