Minor service (oil etc) - do it yourself.
Anything major - Ferntree Gully Nissan.
RE will do a good job of fluids/filters (although I don't like the fluids they use), but if you need diagnostics, ecu resets, parts, trans servicing, can't go past FTG Nissan.
Just make sure that the parts are no available via Import Monster first!
Edited by iamhe77
Whats the pricing like mate?
And thanks for the info guys.
R E customs looks solid.
Just picked my car up from RE Customs, after they installed my highflow. I got a standard service at the same time. Let me tell you, it was very reasonably priced. Speak to Ray and he will give you an idea on price - but i would highly recommend them. I can say that other import specialists i have tried have been a fair bit more expensive.
+1 for R E Customs
Depending on where you are in Melbourne either of these places are really good.
If you live out West
http://www.chasersmotorworks.com.au
I just had my 100,000km service done there which covered the following :
Timing and Accessory Belts
New Water pump
All fluids e.g. Engine, Gearbox, Diff, Transfer Cas (They used Motul and Castrol products so not cheap stuff either)
All up came to about $1200 which I thought was very reasonable.
If you live South East
http://www.statustuning.com/
I haven't had Trent service my car only do some tuning and fitting of my computer and EBC, but I was very pleased with his work. I would go back and use him regularly only he is a bit far away for me to travel.
RE's prices are pretty good.
I don't know what they use now, but back when they did my high flow, they put Martini Racing 10w40 mineral oil in and it drove like it was being strangled.
They were also using Castrol Edge (you have to ask for it), but I don't link how that compares in my car either.
As I said, if you are not picky about what fluids are used, go for it. Ray/Brad/Michael do good work.
Otherwise, you could always take your chosen fluids to RE for use in your service.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
    • @Kinkstaah I've got my list.. but most of them is to do if I ever win the lotto
