Hey Guys.
Was working on my R33 GTS-T Series 2. Put in new plugs. and now the car has never run the same.
I replace the plugs as the car was unstabe under heavy throttle loads.
I put it back together and its running like a WRX.
After this tho....
I bought new CoilPacks, and new plugs again... and gapped them. and changed the fuel filter.
AND it is still running like a shitbucket wrx. tested crank angle sensor and engin compression ratio, and also fuel pressure.
Any Help.
Next step is to have a look at the injectors.
Any suggestions before i take my car to bits?????
Cheers,
Michael
1. whats plugs did u put in? (list the model number and brand please)
2. what gap did you set them too?
gotta feeling you have used the wrong plugs and or at the wrong gap...
could also be an earthing issue, but lets eliminate these items one at a time first...
make sure you have them clipped into the clips properly (i had to use a flat blade screw driver to lever up the plastic tags to clip mine in properly) also i've been told if you've degreased your engine or something lately over the rocket cover that the oil/crap can fall down and short your plugs or some shit.
but its most likely your coils or you've f**ked the gap up
Used standard NGK plugs Part no. PFR5G-11
Gapped at .8
And the coilpacks are brand new. and the resistance has been tested also... all showing up fine.
The problem started when i took the old plugs out. And after replacing everything plug and coilwise its still not running properly. So far 3 sets of plugs.... and counting.
the car also seems to be running rather lean..
But still sounds like its not getting enough fuel or spark or something.
Hamdog.
What do you mean about clipping them into place???? My mechanic mate is doin all the work for me as he owns an R32. So things are pretty much simular.
You say you changed the coils - were they Splitfires or similar, or 2nd-hand stockers? If the latter, it's very possible that one or more of the coils you've swapped on aren't working properly. If it is indeed running lean as you say though (measured, or guessed?), maybe you bumped an injector plug or crimped a line to the fuel filter or something, who knows. The timing might be out too, did you knock the plug on the CAS (front of the engine)? Stuffed AFM/plug? Plastic still on the fuel filter (have seen that before lol)
Does it have a consistent miss at idle? If so, assuming it's a spark issue, pull the plugs one by one and see if any are wet. If they are then your injectors are probably working fine and you've identified the cylinder/cylinders that isn't/aren't firing. Then it's a process of elimination... swap coils around and see if the problem moves with a coil for example, or whether it stays on a given cylinder, swap plugs around, check connectors, clips, earth straps, coil loom, AFM etc. If all else fails, grab a mate with a working S1.5/S2 33 and swap parts until yours runs properly and work it out from there.
Also, IIRC 6s are the stock heat range for plugs. I used to use BCPR6ES, they're coppers and are pretty cheap and did the trick nicely.
Hamdog.
when i changed my coilpacks, i didnt clip the loom/wiring harness into one of the coilpacks properly and after a while it wiggled free and lost connection. therefore a cylinder stop firing
took me ages to realize what i'd done wrong and i just got a flat blade and clipped the tag into it properly.
also check your afm plug ect
i was gonna say have a look at the wiring for the coils, there are chances that some of the wires are broken and earthing, or that the insides of the plug for the coil is not connecting, i had the same thing, but it tunred out to be my sticky injectors.
Normally if it is a plug issue it will be around the 3500 - 4000rpm mark, it will start sounding like a WRX.
If that is the case BKR6E which is a v-power plug or like the one mentioned by Revhead the BCPR6ES will do the job.
Yeah it will def depend on whether the coil packs are bran new or second hand. And usually they will start off ok until they get hot then they start to break down. Try removing one coil pack at a time with the engine running and see which one has no effect when removed. The ones that are working will affect the engines idol when removed the bad one/'s won't. My experience with AFM's is usually they just stop working full stop and thus the engine doesn't run at all. I had one go on my R33 GTR and the engine just died. May be worth checking the igniter unit? I don't know anything about those sorry.
Mate good luck and let us know what the problem was when you solve it.
Hi guys...sort of having a similar problem with my series 1 r33...the car started backfiring about 150km ago, but only under heavy throttle as the car still runs fine at 3500-4500 rpm...it only seems to be when the car is at high boost. The car idles fine and spools without problems, however as soon as i put my foot to the floor and it gets to 14psi it backfires heavily. The oil has been changed under 500km ago and there are no oil leaks and no smoke coming from the exhaust (which i hope to rule out turbo problems). My mate seems to think its def a fuel problem so I changed the plugs on wednesday (put ridiums in and didnt change the gab at all. The plugs are all connected properly to aviod 1 unclipping but :blush: im pretty sure the ridium's have made it worse. Replaced the AFM and even the O2 sensor and still nothing. About to change the plugs again to NGK BKR6E's and see if that makes a difference, but from what I can gather from the reply's above i think my coilpacks are f&*ked. Any ideas before i go out and buy new coilpacks only to find that it may not fix my problem or would i be able to get away with second-hand ones?
Cheers
Brendan
Hi guys...sort of having a similar problem with my series 1 r33...the car started backfiring about 150km ago, but only under heavy throttle as the car still runs fine at 3500-4500 rpm...it only seems to be when the car is at high boost. The car idles fine and spools without problems, however as soon as i put my foot to the floor and it gets to 14psi it backfires heavily. The oil has been changed under 500km ago and there are no oil leaks and no smoke coming from the exhaust (which i hope to rule out turbo problems). My mate seems to think its def a fuel problem so I changed the plugs on wednesday (put ridiums in and didnt change the gab at all. The plugs are all connected properly to aviod 1 unclipping but :yes: im pretty sure the ridium's have made it worse. Replaced the AFM and even the O2 sensor and still nothing. About to change the plugs again to NGK BKR6E's and see if that makes a difference, but from what I can gather from the reply's above i think my coilpacks are f&*ked. Any ideas before i go out and buy new coilpacks only to find that it may not fix my problem or would i be able to get away with second-hand ones?
Cheers
Brendan
I suggest you find someone with the same engine that is running well and swap coil packs for a test. Go for a 5 to 10min drive getting up and over(if possible) the trouble spot and if it runs better than you can safely spend the money on some new coil packs. Also get a gap gauge and re-gap your plugs to .07 which ever plugs you use. If possible use the recommended ones for your model not a referred one unless you've got some serious hp. You'd be surprised at how heat numbers and different types of plugs have an effect on the cars performance.
Mate good luck too.
Edited by shaggy_76
  • 4 weeks later...
Myr33GTS-T try your ignition module it could be stuffed as this was my problem when my car sounded like a wrx haha and shaggy pretty sure it would be the coils as a mate has the exact same problem.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
