bump
Hey mate, im interested in the BMW, send through some more pics please, probably to my mobile if you want
Of the damage mainly, and a few more details please?
Manual?
KMS?
Interior? Leather or cloth?
What part of tas you from?
Thanks,
Michael
0438911374
for sale bmw 318i goes relly well lowered tinted windows angel eye head lights 18" m3 alloys good rubber mp3
lil bit of panel damage in front more pics later $4000post-57621-1250588199_thumb.jpg
very interested more details please ?
post-57621-1250998527_thumb.jpg its a 5 speed manual. front tyers are getting low now i look at them. cloth trim in good cond exepet driver seat is ripped.
250klm on clock . open to offers. hobart
How long has the rego been out mate?
Also, Have you had a quote for the damage?
Why is the rear spoiler on the car in one photo but not the other? Not that i wannt te spoiler, looks way better without it.
So what is damaged still?
To me it looks like, both front guards, bonnet, most likely bonnet latch a well. are they the right headlights for it?
Would you mind if i got a panel beater mate from hobart to go have a look at it?
Thanks
Thanks
the bonnet and front bar are stuffed the two front guards might be fixable dont know. you can get your mate to have a look if ya wont
its got that wing on it now just needs to be painted or chuked out
the lights are after market.
needs rego inspection
for more info call dave on 0406 194 500
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
