Hey all,
I recently changed my plugs to NGK Iridium's. I took it for a drive after they were put in and it went fine right thru the rev range.
About 20mins later i took off in 1st, change to second and nothing happened. I would have my foot down but there would be no power.
I take my foot off the gas for a few seconds then i can feel the power come back on and it is all fine again.
Sometimes when i am at idle the revs will rise to 1600rpm and stay there.
When i change into the next gear (usually into 2nd), is when it happens most of the time.. I can drive it on the highway and keep it at 100kmph (aprox 2900rpm)
It Seems like a boost leak, or something to to with the fuel. It was fine before i change the plugs.
All help is appreciated
new insight to my problem
when the car is playing up it wont hit boost.
I revved it to 5000rpm and the boost guage rose in vacume and came to a stop right on "0".
I can feel the car is about to stall so i put my foot on the gas and nothing happens... AT ALL! it just stalls.
If the car is cold it drives fine.
If the engine is warm but the car has been sitting for a while it is fine.
If the car and engine is warm it drives like a dog!
So when something on my car warms up.. it f@#ks up?
it was the plugs people.
NGK Iridium's
I put my old ones back in and it is all good now.. Just miss fires a bit, which is why i bought the Iridium's in the first place.
They came out with a build up of white crap on them? Does that mean im running to rich or lean?
And why would my car act like this with these plugs?
Try plugs at 0.8 and see how they go
can skylines be tuned to run better with better plugs?
I wasted that $120 so i think i will get them when i get my big service.
do you think that they overheated? Cuz they were fine for the first 5min of driving... Do you think that it wouldnt hit boost because the car could sence they were overheated, so it was like a safety thing.?
I agree wholy with WazR32GTsT A set of coppers are just as good the only reason I can see to use Iridiums is the life span, as it is a bitch to take RB spark plugs out and also puts stress on the coil pack connecters as they end up brittle and can break. They wont give you a performance gain. Coming into summer it wont hurt to put 1 heat range colder plugs in.
NGK Iridium's
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
