Hello Guys,
I am selling these wheels off my 350z, bought them as "a spare part" with my car and they costed 4000 just for the rims from the dealer! I am selling them for 2200 nego. without tyres... but 2800 nego. with new brand new RE040 tyres!
I posted this a couple of days ago, but the thread is gone with the loss data I guess...
Rim and Tyre Spec:
Front:
18" x 8.0J +30 with RE040 225/45/18
Weight: 8.1 kg each
Rear:
18" x 8.5J +33 with RE040 245/45/18
Weight: 8.3 kg each
also if you want the rear tyres to be SO2 255/45/18, the price will be slightly higher as those SO2 are used for only 500km...
I believe these rims can fit R33 and R34 without any problem!
Here are the pics:
cheers,
richie
For those people who sent me PMs to express their interests, would you please sent those PMs again if you are interested in this set of wheels still? My inbox is now empty due to the database failure!
Sorry for causing all the inconveniences!
cheers,
richie
yup... Maxx is correct...
Those are NOT EVEN an option... they are considered as "SPARE PARTS" from nissan.... when I bought this set of wheels, they didn't even want to take those original 18" back... and those wheels cost 4K just for the rims!
These rims are great, the reason that I want to change is go for the bigger ones or even wider ones as the Z car has got HUGE guards!
If any one of you is interested in the price that I offer, PM me!
cheers,
richie
Ok, are they BRAND NEW? not one mark on them?
will they fit an R33 GTST?
Im interested if they are brand new and will go straight onto my car. I just dented my 2 front Nismo LMGT2s worth $800 each !
NOT HAPPY!
Sorry knore,
they aren't brand new.... if you want brand new ones, you will need to pay 4K just for the rims from Nissan dealership... or even if you import them from japan yourself... they will fit GTS-T as well I believe!
As for your case, it might be better off for you to just order another 2 LM GT2 wheels which will be better to buy those rims off me, just my honest opinion.
cheers,
richie
what i meant by brand new is ambiguous :) sorry.
i bascially mean do they have any marks on them?
can anyone confirm they will go stright onto my series 1 1994 R33 GTST ?
They probably would. I am using 18" rims from a 350z track at the moment on my s1 R33 GTST. fit straight on.
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
