Hello Guys,
I am selling these wheels off my 350z, bought them as "a spare part" with my car and they costed 4000 just for the rims from the dealer! I am selling them for 2200 nego. without tyres... but 2800 nego. with new brand new RE040 tyres!
I posted this a couple of days ago, but the thread is gone with the loss data I guess...
Rim and Tyre Spec:
Front:
18" x 8.0J +30 with RE040 225/45/18
Weight: 8.1 kg each
Rear:
18" x 8.5J +33 with RE040 245/45/18
Weight: 8.3 kg each
also if you want the rear tyres to be SO2 255/45/18, the price will be slightly higher as those SO2 are used for only 500km...
I believe these rims can fit R33 and R34 without any problem!
Here are the pics:
cheers,
richie
For those people who sent me PMs to express their interests, would you please sent those PMs again if you are interested in this set of wheels still? My inbox is now empty due to the database failure!
Sorry for causing all the inconveniences!
cheers,
richie
yup... Maxx is correct...
Those are NOT EVEN an option... they are considered as "SPARE PARTS" from nissan.... when I bought this set of wheels, they didn't even want to take those original 18" back... and those wheels cost 4K just for the rims!
These rims are great, the reason that I want to change is go for the bigger ones or even wider ones as the Z car has got HUGE guards!
If any one of you is interested in the price that I offer, PM me!
cheers,
richie
Ok, are they BRAND NEW? not one mark on them?
will they fit an R33 GTST?
Im interested if they are brand new and will go straight onto my car. I just dented my 2 front Nismo LMGT2s worth $800 each !
NOT HAPPY!
Sorry knore,
they aren't brand new.... if you want brand new ones, you will need to pay 4K just for the rims from Nissan dealership... or even if you import them from japan yourself... they will fit GTS-T as well I believe!
As for your case, it might be better off for you to just order another 2 LM GT2 wheels which will be better to buy those rims off me, just my honest opinion.
cheers,
richie
what i meant by brand new is ambiguous :) sorry.
i bascially mean do they have any marks on them?
can anyone confirm they will go stright onto my series 1 1994 R33 GTST ?
They probably would. I am using 18" rims from a 350z track at the moment on my s1 R33 GTST. fit straight on.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
