OK! So, I'm looking for a colour sample of something thats in my head but many pages of google image is not helping. Oh what do I do!? Well, I came up with a little something which may also be used anything other than a colour sample. Each step has an image so it should be pretty easy to follow!
1. Create a new image. Set it to 500px * 500px
2. Fill the background with any colour other than Black or White
3. Goto Filter -> Render -> Lighting Effects
4. Change the Light Type to "Omni". As far as lighting position and properties is concerned, please ref to image below:
5. Duplicate the current layer (Background). Hint: Ctrl+J
6. Auto-correct the Levels (Ctrl+Shift+L).
7. Change the Layer Type to "Colour Dodge". Also, change the Fill % to ~50% (This will vary on taste etc)
8. Create a New Layer. Fill it Black, and goto Filter -> Noise -> Add Noise. Use settings as per the image:
9. Follow Step 7 for the New Layer.
10. For the fun part! Select the "Background" Layer and goto Hue/Saturation (Either via Image -> Adjustments, or via shortcut (Ctrl+U)).
Tick the "Colourise" checkbox, Move the Saturation slider to 100. Then, move your Hue slider across to the colour that suits. For tutorial purposes, ill choose a blueish colour (200-250 Hue).
Now, youll notice that the bright spot is intensly white. So, move the Lightness slider down to a tone that suits you.
There you have it! My final product has a "clear coat" so to speak, if you want to know about that, just post! See below :D
Cheers
https://www.sau.com.au/forums/topic/284044-the-un-named-tutorial/
  • 1 month later...
    • Don't think that can fit in physically. Are you referring to this?    If it happens again, I'm going to get the nismo ones.
    • I bought the 1/18 scale celica and nsx from Justin and they are very detailed and good quality. I will definitely be interested in others in the series as they come out
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
