INTRODUCING THE NEW 595RS-R ULTRA HIGH PERFORMANCE (UHP) TYRE
King of sport – 595RS-R with reinforced carcass and sidewall offers easy handling while taking the abuse of driving at high speed as well as superior grip and cornering stability, is a secret weapon for the championship. Recognized by Japanese professionals and selected as the official tire to Australia 2007 X Challenge competition powered by Lotus.
Features
New, semi-slick, sport competition 595RS-R - designed for exceptional traction and grip. Cutting-edge technological advances in design, construction, pattern and compounds. Best performance in its class - a street legal competition tyre with the characteristics of a slick.
* Lateral grooves substantially exterminate stiffness on shoulder blocks to upgrade traction and riding comfort.
* Tread patterns on shoulder block provide lateral driving stability while cornering.
* Uni-directional V-shaped main groove design enhances both sport look and water distribution.
* Wide angle grooves improve consistency on tread blocks thereby permitting more serious grip.
* The modern, feather-like tread pattern incorporates stylish image and outstanding responsiveness.
* Embossed letters on the sidewall featured with unique and personal characteristics.
Designed for use on all high performance vehicles
235/45/17- RRP $1236 SPECIAL $1000 SAVE $236
255/40/17- RRP $1352 SPECIAL $1100 SAVE $252
235/40/18- RRP $1276 SPECIAL $1050 SAVE $226
245/35/18- RRP $1448 SPECIAL $1200 SAVE $248
255/35/18- RRP $1480 SPECIAL $1250 SAVE $230
265/35/18- RRP $1500 SPECIAL $1270 SAVE $230
ABOVE PRICES ARE FOR A SET OF 4
http://www.federaltyres.com.au/specs/ss595.pdf
https://www.sau.com.au/forums/topic/284069-otr-federal-595rs-r/
Price for both choices (so you'll end up giving me total of 4 different prices) :)
265/35or40/R18 (2tyres+postage)
or
285/30 or 35/R18 (2tyres+postage)
posted to Eden Hills, SA, 5050
PM me the reply thanks
Cheers Ripp3r
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
