Hey,
Im having trouble getting the correct belt numbers for my GT, Repco etc dont have a listing for the Neo GT and I dont want to end up with the wrong ones. Im pretty sure they arnt the same as the Turbo model nor the 33 Non Turbo... I could be wrong though.
I have Bosch belt numbers but they dont match up with the ones Repco have....
Any help would be good. :P
I need Aircon, Alternator/Water pump and power steering belts.
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/
The belt numbers should be useful to Repco anyway. Belt 4TK910, for example, is also 40910 on the parts list. "4" stands for 4 ribs, and "910" is the length, and so on with the other belts. Have you priced them at Nissan?
I get my car back at lunchtime ... I peek under the bonnet and get my numbers. T and non-T Neo motors should be the same surely.
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4776105
Ah Ok,
Nah I havent called Nissan....
You would think they would be the same but they have different oil filters and stuff so I just wanted to make sure.
Im desperate, the one bird under my bonnet now sounds more like a jungle.
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4776139
While on the topic of belts, etc. Does anyone have the Gates Racing Belt Codes for the R33GTST? I am looking mainly at ruby here, cos of the place he got his from.
http://cgi.ebay.com.au/NISSAN-SKYLINE-R33-...p3286.m20.l1116
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4776587
Just double check your stock belts first against what is quoted in that ebay link given by Penny. They did get one of my belts wrong ... but made up for it.
This Mico-V /Drive belt kit contains the following parts: 1x 4PK835R 1x 4PK865R 1x 4PK925R
I believe you need something like 1x 4PK865R 1x 4PK890R and 1x 4PK925R
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4776653
gates??? more like goatse :)
Really?! Why's that?
Thank you :P
Thanks Ruby, its just that i don't want to go through what you did, as its going to be a few weeks/months before they get installed and if its the wrong ones, then they may not swap after that long a time.
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4777065
just that dayco have a far more superior warranty setup if need be...also all the R&D that have gone into dayco exceeds the quality of gates belts....im not just saying this because i sell dayco....but from experiences with both products on my own cars
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4777972
Can you send me a pm with prices for a set of Dayco belts for my car? Also if you can get a timing belt too.
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4778034
Replaced all my belts... and guess what...
ITs still F&%* Sqeeking! Tightened them twice now. Then thought there may be left over belt grip making the noise so I degreased the lot and it didnt help.
I am sooo over it.
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4800576
I am sooo over it.
Shoot down to my place and I'll take a peek under the bonnet for you. Perhaps waterpump?
https://www.sau.com.au/forums/topic/284075-r34-gt-belts/#findComment-4800866
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
