Hey,
Its not the timing belt, that was changed and isnt due for replacement till 170,000kms
If i spray brake cleaner on the altenator/waterpump belt it will change sounds.....
The waterpump has no leaks or nothing either. How can you tell if its bearings or seals?....
Hey,
If you can get the long (straw-type) nozzle of some WD40 to the waterpump, there is a hole in it for lubrication, squirt some in (with the engine off of course), start car and see if the noise subsides. If it does, add in some handy oil if you can get some in that tight spot (use a straw etc). If the noise returns ... then its time for another water pump.
I had a waterpump die on my silver RS4. Started off as noise (bearings) then eventually started leaking thru the seals on the shaft. While waiting for a new pump to come via post, the small leak turned into a total pump failure. :D
usually you can hear if a bearing is gone if you have a long screwdriver....whilist the engine is running, put the sharp end of the screwdriveron either the water pump..or pulley housing..without touching the pulleys (obviously)...then put your ear up against the handle of the screwdriver...you will ba able to hear a noise that will determine if it is actually bearing noise...kinda like a stethoscope...or putting your ear on the train line
Hole for the water pump is actually underneath as far as i remember. Alternator bearings to get noisy too. Are you sure the belts are seated properly in the groves of the pulleys? A spray with CRC Belt Grip could also help.
The guys are heading in the right direction, were the cam seals and crank seal done with the timing belt? Possibly over tightened belts? Should be about 10mm movement up and down at the belts longest point between pulleys. Over tightening will put extra side load on bearing and chew them out a lot quicker.
I used tones of belt grip on my old belts and it helped for a small amount of time but in the end i had to put it on every week and it kinda made it like glue... My old belts wernt even in bad condition either.
I don't think they are to tight but I'll check again. They are Dayco belts and are lined up perfectly. Considering it did it with the old and new ones it's very much sounding like bearings.
Does anyone know how much they cost to replace? Oh and the sound is definatly not from the timing belt.
New alternator bearing you could get done at the place on Carlton rd in Gawler, cant remember thier name but they are an electric motor rewinders. Water pump, better of getting a new one through Nissan, dont go for the cheaper option they're shite also dont belive parts guys when they say RB30 is the same. Power steering pump would have to be taken to someone like ReCar at St Agnes or similar.
I'd start with the alternator and maybe water pump. Only down side with the water pump is you have to take off all your timing belt cover, harmonic balancer(unless you can get the bottom cover off without removing it),and timing belt.
Hope it all goes well for you Penny
Sounds like your spot on Penny. I wouldn't go pricing a new one through Nissan though. Check that place on Carlton Rd out, if they're still there. They should be able to put new bearings in and give it a freshen up inside.
exactly....RB30 pumps are different...only slightly though....the outside looks the same..its just mounted differently...we stock aftermarket ones at motor traders :blink: and i could do a good price if that ends up being the problem :blink:
Penny, I've got an RB25 pump in my garage, new and unused, still wrapped in plastic. My waterpump checked out okay when I did my cam belt, so I never fitted it.
There if you're interested. Sorry for stealing clientele Ben :blink:
:blink:
Cool, I know where to come if its my waterpump then! :blink:
Im going to get the altenator checked as soon as I can. It would make sense if it was that because I heard some whining about a month ago and thought that could have been my altenator...... It could still be whining but i cant hear it over the squeeking.
I hate driving it while its noisy, but I dont have a choice right now.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
