yeah, the only issue I think with them in the past that I have seen has been, poor installation, or other user related problems (like not understanding what to tell the pump to do). and possibly some claims of reliability. but I would not have a problem using one, I can't possibly see how it's cheaper than using a factory or N1 water pump though. you need to get the pump, controller, a place to mount it, wiring (pretty decent current drain), do something with the factory pump housing, then plumb it all up. it's a fair bit of work and a fair cost of parts. it's not like you can just cut your radiator hose in half and stick in in, then wire it up to an on/off switch. it needs some thought to work properly.
if you do do it properly and have the controller set-up well then there are some good advantages to using one and it can control temps much better than a standard crank driven pump and wax thermostat combo. plus you can do things like have the coolant continue to circulate after shut-off to help cool things down and stop the coolant temp in the engine spiking up after shutdown (if you have a proper temp gauge check what happens to engine coolant temp after you shut off the engine!!!).
that and the fact that there is nothing really wrong with the factory set-up... sure a good ewp is an improvement but it's a lot of dough to spend to fix something that aint broke.
I've got one for my 300ZX with a VH45DE. They are physically large and can be a bit tricky to fit in a good spot. They must NOT be run dry as they have a ceramic mechanical seal just like a house water pump. I got the digital controller with mine too, just had to drill and tap the standard pipes to suit the new CTS. I'm just blanking the standard water pump housing with some plate and have removed the standard thermostat. I'm still using the standard pipes. You could just gut the standard pump if you don't want to blank it, or wish to retain the clutch fan.
My pump was about $220 secondhand but unused, controller was $240 or so, I already had all the steel and drills and taps etc.
+1 i have noticed, wondered why this happens; must be an energy conduction issue. Ive seen (with my easy driving style) rises of 5degrees sometimes
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
