hey guys, been a looong time since ive posted up on here mainly cause i dont live over in Australia. Well ive got an RB25DET NEO in my S chassis "240sx" here in the US, and i am in need of a replacement VCT (variable cam timing) solenoid. right now its leaking oil thru the connector and causing the car to run like crap..These engines were never sold over here so you can imagine trying to source one of these parts is not exactly easy. I would very much appreciate if anyone on here could help me out. i wouldnt even mind getting brand new one from the dealer. If one of you guys could check into that ii would be very greatful. i know im not a very big participant on this forum and for that im sorry, but I am a fellow RB owner and I am in need of some help.
thanks in advance everyone
Mark
https://www.sau.com.au/forums/topic/284158-wtb-vct-solenoid-rb25det-neo/
afaik r33 ones are the samd just different plugs which are easy to get
thanks for teh quick response, i honestly dont know what the R33 version looks like...would you happen to have a picture of it ? i have seen the VCT solenoid in my car , i have removed and have seen the entire peice without it installed in the engine. if i could see a complete picture of the VCT solenoid without it in the head it would give me a good idea if it will in fact work. not that i dont trust you at all but i have heard thru numerous people that they are in fact different. i just would like to be sure is all.
anybody?!?!
anybody?!?!
well thanks anyways guys, i had a buddy in japan actually pic me one up from a wrecked ER34. and at the same time i found the actual part number converted to a US nissan part number and i can get me one here in the state for around 100.00 bucks.
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
