heya everyone,
i have a series 3 r33 gtr non v-spec
now ever since i have bought this car. i have noticed that it feels like it has a lsd diff in it.
when i turn a corner to do lets say a 3-point turn, it will make the doo doo doo noise like the rear wheels are tryna both spin.
it has always done it. now im not sure thats why im asking you guys if u could help me out as it has me stuffed lol
so my real question is. do the series 3 come out with lsd ?? or maybe the guy in japan fitted a lsd into it ??
there is no light on the dash like the v-specs do by the way
tanks for the help in advance
chris.
https://www.sau.com.au/forums/topic/284161-question-about-my-car/
You should have a LSD light in your dash, in the centre between your Speedo and Tacho.
If it is making a "doo doo doo" noise and both wheels are spinning, it might sound like you have a Lock Diff.
1 or 2 Way Lock Diff, I am not too sure...
all GTR's have LSDs (so do all GTSt's BTW)
non Vspec have a mechanical LSD diff... its got clutch packs in it so it will lock on tight turns depending on how worn the clutch packs are etc... it may have been modified to lock tighter/earlier... the Vspec diff is an electronically controlled viscous (fluid) diff (which is what the light is for on Vspecs)
mine does the same as yours in car parks etc and has not been modified... its a non Vspec... my old GTSt had a Cusco 2 way mechanical in it and it was even louder and more aggressive... but also made loud clunking sound and vibration through the driveline, I'm sure you would know if you had an aftermarket mechanical diff, they are pretty obnoxious lol
ahh ok that makes perfect sence... sweet so now i know i do have an lsd diff :D
thanks for the info guys
it has the torque split bottle in the boot
That's for the ATESSA system, nothing to do with LSD/non-LSD.
GTR's had LSD on the rear's out of the factory, if you have a R33 , finned diff's are Viccous LSD, non-finned is mechanical.
I think R32 might have been the other way around.
Either way, unless someone downgraded you to non-LSD you have one :laugh:
i get a few clunks in my drivetrain (r32 gtst), like crusing in 5th gear going say 60, backing off the accelrator and going back on, even if its not heavily, the rear end seams to knock abit,
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I can do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not! It's well within the service manual specs...but they are very open
