The biggest issue is usually the ignition coil packs, if/when you test drive the car, put your foot on the brake and put your foot on the gas, this tests the coils under load and if they're are faulty, you will be able to hear it.
Also be sure you check for rust, near the front strut bruce and in the boot wells. If you can go for a 2000-2001 or a series 2 model as the price difference isnt that much greater
All the best, happy hunting!
Danny
what exactly should i be listening for?
well if the car doesnt feel smooth reving and if u hear sorta like bop bop bop... it will be hesitant, ie u put ur foot down and though the revs it coughs a splutters... thats sign of faulty coils or spark plugs...
2 years of driving my R34, done around 40,000km. One track day and not had a problem with the coil packs yet. Although splitfires will be on the list when I do my next round of mods just because of how common it seems to be for the stockers to give up.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
