  • Replies 59
Ref the other Dyno thread.. thats how you convert it.. thats why I said what's shown on the dyno graph probably isn't relative to actual torque.. I think it's some sort of different measurement called "tractive effort".. You'll have to ask our resident dyno operators..
This was the First ever Shootout in Perth in Accredited shootout mode.We updated the weather conditions for every car using the weather station on the wall so your readings were very accurate and any body that thinks the readings were wrong can fax their graph to Dyno Dynamics and they can tell you every thing i did right or wrong by the details on the bottom of the page.
I garranty that this was the most accurate Dyno comp ever in Perth.
Awesome day well organized and run.
Couldnt help notice the two highest readings came from 4 cylinder cars.....hmmmm?(stir stir)
Maybe the six cylinder tractors can compete next time!
Damn I should have turned up :rofl: Just need maybe 1/2 a psi of boost to beat that 344hp :)
was a good day
congrats to john for his 299.5hp with his stock turbo'd soarer (not flowed either) only just beaten in 2.5 litre class by big turbo/external gate equipped r33 which beat him by like 3hp hehe
look forward to the next one
So when do we see the results!?
Yeah do we have a listing of yet of all the winners and power readings? or are we still waiting for the drug test to come through?
P.S Steve thanks for your help the other day! Sly running nicely now!
Will be in the next dyno comp!!
Guest
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
    • That's exactly what I told myself. I'm happy it came out.
    • My bet is there's a fuse somewhere you blew that feeds power to the ECU. Or you've bumped something out behind the dash board.
