Hi Guys,
We have been selling these for while now and can get them real quick, so if you need good handling tyres like the KU36. Please give us a call..
Designed for SCCA racing that demands high Uniform Tire Quality Grades, this incredible tire delivers unrivaled dry grip with split-second steering response, and its unique footprint is designed to deliver consistent handling performance at high G-forces.
Special Features
* Low void asymmetric tread pattern with circumferential grooving for high cornering grip.
* Ultra fine carbon black compounding for maximum traction.
* Ultra wide tread contact with highly rounded shoulders for optimized footprint shape during high lateral loads.
* Developed for quick autocross warm-up while maintaining race track durability.
* With a W speed rating, the tire delivers an optimum run temperature of 203 degrees Fahrenheit.
* UTQG rating of 180 AA/A.
Comparable Competitor Products
Falken Azenis RT-615, Yokohama ADVAN Neova AD07
205/50/15 KU36 $155.00
215/45/16 KU36 $135.00
225/50/16 KU36 $155.00
215/45/17 KU36 $165.00
225/45/17 KU36 $195.00
235/45/17 KU36 $170.00
245/40/17 KU36 $215.00
245/45/17 KU36 $205.00
255/40/17 KU36 $230.00
275/40/17 KU36 $250.00
285/40/17 KU36 $260.00
295/35/17 KU36 $235.00
315/35/17 KU36 $250.00
335/35/17 KU36 $255.00
225/40/18 KU36 $235.00
225/45/18 KU36 $235.00
235/40/18 KU36 $210.00
245/35/18 KU36 $210.00
245/40/18 KU36 $255.00
265/35/18 KU36 $240.00
275/35/18 KU36 $275.00
285/35/19 KU36 $270.00
https://www.sau.com.au/forums/topic/284228-otr-kuhmo-ku36/
  • Replies 121
im interested in these tyres.
are they still good for road use and still handle ok in the wet because i do most of my driving on the street.
also how much for 4 of them my tyre size is 235/45/r17.
thanks.
scott.
https://www.sau.com.au/forums/topic/284228-otr-kuhmo-ku36/#findComment-4778879
thanks.
scott.
They are extremely grippy in the dry and not bad in the wet either can do Fitted $700
https://www.sau.com.au/forums/topic/284228-otr-kuhmo-ku36/#findComment-4778927
    • Gotcha, I mean that is at least good to hear. Are there signs, or troubleshooting tips to make sure the transmission is operating properly?
    • Well thats probably not gonna happen right away. LOL
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
