Hi Guys,
We have been selling these for while now and can get them real quick, so if you need good handling tyres like the KU36. Please give us a call..
Designed for SCCA racing that demands high Uniform Tire Quality Grades, this incredible tire delivers unrivaled dry grip with split-second steering response, and its unique footprint is designed to deliver consistent handling performance at high G-forces.
Special Features
* Low void asymmetric tread pattern with circumferential grooving for high cornering grip.
* Ultra fine carbon black compounding for maximum traction.
* Ultra wide tread contact with highly rounded shoulders for optimized footprint shape during high lateral loads.
* Developed for quick autocross warm-up while maintaining race track durability.
* With a W speed rating, the tire delivers an optimum run temperature of 203 degrees Fahrenheit.
* UTQG rating of 180 AA/A.
Comparable Competitor Products
Falken Azenis RT-615, Yokohama ADVAN Neova AD07
205/50/15 KU36 $155.00
215/45/16 KU36 $135.00
225/50/16 KU36 $155.00
215/45/17 KU36 $165.00
225/45/17 KU36 $195.00
235/45/17 KU36 $170.00
245/40/17 KU36 $215.00
245/45/17 KU36 $205.00
255/40/17 KU36 $230.00
275/40/17 KU36 $250.00
285/40/17 KU36 $260.00
295/35/17 KU36 $235.00
315/35/17 KU36 $250.00
335/35/17 KU36 $255.00
225/40/18 KU36 $235.00
225/45/18 KU36 $235.00
235/40/18 KU36 $210.00
245/35/18 KU36 $210.00
245/40/18 KU36 $255.00
265/35/18 KU36 $240.00
275/35/18 KU36 $275.00
285/35/19 KU36 $270.00
https://www.sau.com.au/forums/topic/284228-otr-kuhmo-ku36/
  • Replies 121
im interested in these tyres.
are they still good for road use and still handle ok in the wet because i do most of my driving on the street.
also how much for 4 of them my tyre size is 235/45/r17.
thanks.
scott.
https://www.sau.com.au/forums/topic/284228-otr-kuhmo-ku36/#findComment-4778879
thanks.
scott.
They are extremely grippy in the dry and not bad in the wet either can do Fitted $700
https://www.sau.com.au/forums/topic/284228-otr-kuhmo-ku36/#findComment-4778927
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
    • I love it aye. The ability to switch to RWD on the fly can be handy for certain situations.... I can adjust the dial to reduce oversteer out of the corners. I've noticed I can be on the power earlier out of corners and it feels like its on rails compared to the factory system. The factory system would be a bit slow out of the corners and give oversteer. And if you don't like that it is super easy to adjust the front wheel bias.  I would definitely recommend the unit for someone who is looking to have a tunable 4WD, It can be set much more aggressive than factory. And being able to turn off 4WD with a switch has some benefits.
    • Damn this looks so good. I wanna catch the punks who touched the car. That made me angry.
