  • Replies 716
Posted Images
Id assume the stock girdle strengthens to front to back flex, and this would strengthen the side flex
but I'dsuggest to speak with platinum racing for more details on it, im aware they have 2 products 1 is the brace (purple) the other is a brace and awd conversion (blue)
Sump rail and girdle are milled for exact height, the edges of the girdle are machined at an exact angle on a mill, 32 holes are drilled and tapped on the sump rail and girdle for it to bolt onto
Yeah but there is a good chance only 1 in 50 people will actually understand the details, which i have skipped some detail (i can add all the maths with all working out in as well if you like, would be a very long post :P )
Oh and I've ground 29 thou off so far, re cc'd it and its now at 64cc's which would make it 8.67:1CR (before with the 69.6 would have been 8.06:1CR)
And Fatz you think Skylines are high maintenance wait till the little one pokes it's head out omg they eat any spare time whole.
I have an 11 week old and between work, house and him I am flat out and f**ked if I could tell you where all the time actually goes hehe but when they look, smile and laugh at you it's all worth it.
Well i took another 15 thou off, im at 62.1cc's
ok the comp ratio maths
SV
bore x stroke
86.5 x 86.5 / 4 = 1870.5625
x 3.142 x 85 = 499,571.13688
/ 1000 = 499.57113 (SV)
Engine cc's
4.99.57113 x 6 = 2,997.42678cc's
/ 1000 = 2.99743 litre
CV
Head gasket
88 x 88 / 4 = 1936
x 3.142 x 1.2 = 7299.4944
/ 1000 = 7.29949
Deck to top ring
x 3.142 x 6 = 35,263.84425
/ 1000 = 35.26384
85.65 x 85.65 / 4 = 1833.98063
x 3.142 x 6 = 34,574.20284
/ 1000 = 34.5742
35.26384 - 34.5742 = 0.68964
Piston dome volume
x 3.142 x 1.397 = 8,050.02689
/ 1000 = 8.05003
Volume around dome measures 1.8cc's
8.05003 - 1.8 = 6.25
piston above deck height
x 3.142 x 0.1016 = 585.4565
/ 1000 = 0.58546
7.29949 + 0.68964 - 6.25 - 0.58546 = 1.15367
+ Head cc's
69.6 + 1.15367 = 70.75367
+ 499.57113 = 570.3248
/ 70.75367 = 8.06 :1
Also did
64cc's = 8.67:1
62 = 8.91:1
60 = 9.17:1
61 = 9.04:1
61.5 = 8.97:1
61.3 = 8.99:1
61.2 = 9.01:1
So that how i worked out it needed between 61.2 and 61.3
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
