I'm unsure as to what to do to my new car.
I'm going to lower it, try get hold of some TE37 silver rims.
However, I'm unsure as to what size rims to get, and whether or not to get a spoiler? I don't particularly want a full body kit as I like the 'clean' look.
http://i.ebayimg.com/08/!B(kHRj!B2...77PmJVg~~_1.JPG
http://i.ebayimg.com/01/!B(kHSy!Bm...77,epEQ~~_1.JPG
What do you guys think?
https://www.sau.com.au/forums/topic/284265-r34-1998-gt/
Lower it for sure, 17" or 18" TE37 Wheels, see if you can find the Nissan Factory Aero body kit, they usually look nice.
Here is llama au (Juliette's) car.
It one of the best subtle body kits to give the clean look you want IMO.
https://www.sau.com.au/forums/topic/284265-r34-1998-gt/#findComment-4778782
I have just the regular GT-T spoiler on mine and I really like it (gives it a tuff sleek look IMO), the GT-R wing suits is also.
IMO coupes look good with wings, sedans good without.
https://www.sau.com.au/forums/topic/284265-r34-1998-gt/#findComment-4779426
I absolutely agree :down:
https://www.sau.com.au/forums/topic/284265-r34-1998-gt/#findComment-4779531
^^It's should, same car but one is N/A and the other is Turbo.
Just interchange the boot lids with a spoiler on it.
But 2 door R34s can only interchange with 2 doors R34's only cuz I think the 4 door boot lids are slightly different as the rear tail lights are a different shape, slightly...
https://www.sau.com.au/forums/topic/284265-r34-1998-gt/#findComment-4780414
Okay, now I just need to find a r34 KV2 silver bootlid with a spoiler!
good choice :cool: then some JDM rims + coilovers and your set :D
on rims, get some CE28n or TE37 or the nismo lm4 or the work xd9's or work 11r's or volk gtc's
YUM !!!!!! *Droolz* over all the rims above haha
https://www.sau.com.au/forums/topic/284265-r34-1998-gt/#findComment-4782358
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
