Cod Gamer Tags On 360
OB55ES
 Share
Hey all,
If this isnt allowed please delete the post but i thought that we could have a list
of gamer tags so can get some mass games started at some point!
mine is OB55ES so please feel free to add me and get a game started sometime!!
Mitch
 Share
    • I've looked at some oval stuff but still deciding what material to use for the back half to the muffler.   Yeah I do all my own stuff with ecu setup and have it sorted before generally paying someone (my old work) to do base runs and a few power runs then I'll do anything else myself at track or after review data. It's hard to find  a dyno owner these days that will hire out to random.
    • Injectors are told by the ECU to open for certain amounts of time. If the injector flows more fuel, but the ECU doesn't know this, and is told to open for the same amount of time as the stock, smaller injector, then the larger injector will flow too much fuel/more fuel than the engine/ecu is expecting. You absolutely need an ECU to control injectors. You don't need a tune for a fuel pump (because your fuel pressure should remain the same assuming the regulator works). You don't need a tune for an exhaust (the parameters for fuel and air going into the motor have not changed much) You don't need a tune for an Intercooler (the parameters for fuel and air going into the motor have not changed much, it's just the air is cooler) Yes, forum regulars, I know that you really should get a tune for an Exhaust, and Intercooler. These *will* affect the tune, but the stock tune does have some leniency to it with stock AFM and Injectors. Intercooler and Exhaust will fit within this wiggle room. So will running a boost tee to about 10psi, which is a very old way of increasing boost which is not worth doing in 2024. The ECU is vital. It runs the whole show. Most people change injectors and ECU at the same time for this reason. Some people load base maps on some ECU's that have ballpark figures for injector sizing. Sometimes injector manufacturers are really great and tell you what parameters to input into your ECU, which is something you can do with your new shiny ECU. For a beginner, this may enable you to drive to the tuner to have an expert do the rest. Otherwise, you're installing injectors and ECU at home, and paying for a tow to a dyno. Or, you take the car to a workshop (be happy to travel across Melb for the right shop) and someone who knows RB will be able to source/provide/install injectors and tune the car at the same time if they have a dyno or access to a dyno. The reason so many people DIY things here is because finding said workshop is hard, expensive, potentially getting things wrong with miscommunication/other.
    • @robbo_rb180 do you tune your cars yourself or do you send them to someone? If you do it yourself, do you hire a dyno, or tune it after logging it at the track? Meaning like touch ups when you tweak or modify something a bit
    • What does everyone think about PSR vs Garrett? I've got a genuine G30-770 but would probably get away with a G35-900 because I've got a sequential. Are the real ones worth more than double the price?
    • @Duncan That's good to know. The luck I've been having with the car lately, a part of me was thinking something has gone wrong which is why the voltage is lower now.
