hey guys and girls
first off sorry if this in the wrong section
i have done a rb conversion in my s13..
and it hits the bonnet... :rolleyes:
i have been told to use bonnet spacers..
what are they... they go in between the bonnet and the hinges dont they ?..
could i just use washers?..and are they leagle
or is there anotther way i can do it.. (aka diffrent engine mounts... cut the ribbing in the bonnet)
i posted on niss silv and got reemed..
any helpfull help would perfect thanks..
cheers roger
Edited by regor
https://www.sau.com.au/forums/topic/284286-bonnet-spacer/
if you are worried about legalities - dont cut the reinforcements
yes you can use washers to space the bonnet up at the rear- but remember to get longer M6 bolts to match the spacers
cannot comment on the engine mounts option, it is possible to use others/mod yours but it may not be viable depending on crossmember clearance, ground clearance and drive train alignment - do some more google searching there is sure to be a few guides
https://www.sau.com.au/forums/topic/284286-bonnet-spacer/#findComment-4779677
ok sounds good..
and also while i am hear..
when ur getting rid of hicas in the power steering pump..
i have been to pull out the veins and plug up the hole..
the veins are the little retanglle thingys that are on the wheel thingy... correct?
cheers roger
thanks for the help guys
https://www.sau.com.au/forums/topic/284286-bonnet-spacer/#findComment-4781323
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
