Hi Guys
Have Xbox 360 with 20gb HDD for sale.
Comes with Xbox 360 Genuine Wireless Network Adaptor so you can connect to net wirelessly and play online.
4 controllers (2 x black, 1 x red, 1 x white). 3 have rechargeable battery packs, I have 3 x controller cables for these that you can charge these controllers whilst playing at the same time. Last controller doesnt have rechargeable battery pack just standard battery pack that fits 2 x AA batteries.
Console works fine, this was a brand new replacement I got last year under warranty after my original hit the 3 red rings of death, so as this is a new model, it is more up to date and less prone to those earlier console issues.
Comes with HDMI cable. Have original box.
Looking for $380 pick up from Sydney/Fairfield or $400 posted. Remember it costs around $60 for each controller and the network adaptor itself goes for about $130 or so.
Have these games for Xbox 360 if anyone is interested:
Prince of Persia - $35
Star Wars - The Force Unleashed - $30
Call of Duty 4 - Modern Warfare - $50
Forza 2 - $20
Fifa 09 - $30
Street Fighter IV - $55
Fable 2 - $45
Soul Caliber IV - $20
Also Have -
Capcom vs SNK 2 EO original xbox game - this is rare? so dunno how to price it, make me an offer
& Marvel vs. Capcom 2 original xbox game - make an offer
Edited by vudoo
PM with how much you want for them individually and as a bundle
1x white controller
1x wireless network adapter
1x HDMI cable
2x rechargable batteries
2x charging cable
COD 4
Edited by silver reflection
odd... can't seem to edit my post
can you post pics of the console, in particular the label near where the power plug goes in, i'd like to see what the power rating is
is it still under warranty ? if so how long ?
silver reflection i will pm you tonight with pics and pricing as requested
i will not be separating the hdmi cable, i would like to keep that in the bundle to go with the console
pms replied to, network adapter is sold pending payment/delivery/pickup confirmation
once i can confirm network adapter sold i will adjust my asking price for the console bundle accordingly.
here are some pics, u can see the extra charge and play cable on the right, and the xbox HDMI cable on the left
pic doesn't include the power pack for the console because i was too lazy to pull it out from behind my media cabinet, but it looks like a standard xbox 360 powerpack, nothing special.
Wireles Network Adaptor SOLD
Xbox 360 Bundle Update:
Console + 20GB HD, + 4 x wireless controllers + 3 x play and charge packs + Media Remote control + HDMI cable
price drop - looking for $320 pick up Sydney
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
