Well as some of you may or may not know... a month or two ago my R33 was hit in the ass while i was parked at a red light.
after that incident the car ended up like this:
I then sold the car onto a friend who has taken to attempting to fix it up to use as a drift/track car or even re register it and drive it.
His progress so far:
1. Cut into bits
2. bent up boot floorpan replaced
3. Shell re-attached and taced on
Still alot of work to go yet obviously, but its coming along nicely
I was estimated $8000 - $11000 to have this repaired at a body shop.
So far he has spent $500 on a quarter cut from a wreckers and a fair few days of his time.
Next step is full weld up, grind back, then a million hours of sanding.
Just thought some of you guys might be interested as i think he's done a top job so far. (he has never attempted any body work bar flaring guards with a guard roller before)
Cheers
Steve
https://www.sau.com.au/forums/topic/284301-the-restoration/
real nice job he's doing there
only suggestion i can make is to take more paint off around the joins before welding, dont want any weaknesses introducted through impurities in the weld
that and the normal tack move tack move process for panel welding.
hope it all works out clean
https://www.sau.com.au/forums/topic/284301-the-restoration/#findComment-4779668
I did this to my silvia when i crashed it in the hills. joins between the rear taillights and half way down the left qtr panel... Like said above make sure you take your time with the welding... .8 sheet is too easy to warp... if you have a tig it's much easier... when your done make sure you seal the inside with zinc fortified paint or alike (and any panels that are to be spot welded back at the seams must be painted before they are joined..)
It's really not all that hard if you use common sense. best for me was finding a silvia at U-pull it. so got the whole qtr for $88 :P . cost me les than $130 all done with spray can paint (still needs a proper paint job but...)
Good that you can take some time over it, i had to get mine done in one sunday!!
https://www.sau.com.au/forums/topic/284301-the-restoration/#findComment-4781651
no idea man haha, he seems to be doing alright though.
I'll ask him about it when i see him next though.
im pretty sure he's using it with gas but im not 100%
Wow, good shiz!
How good is your friend finding the CigWeld mig for welding body panels? I'm assuming you are using it with gas?
They are quite good value units, I am curious to see how good they are!
he's also looking for a rear windscreen, so if anyones got one let me know! cheers
Edited by stenve
https://www.sau.com.au/forums/topic/284301-the-restoration/#findComment-4804085
  • 1 month later...
been a while since i've thrown up an update so heres where it's at now:
its all sanded back smooth and joined and aligned and in undercoat
front bar got a redoing as well
it cost him something like $400 for 2 litres of paint or something insane
Its a 3 step system which involves a silver base coat
then a diluted layer of green so it isnt so opaque and the silver shines through to create the gold pearl.
then the clear coat.
He's a bit scared to paint it now because he has to blend and somehow try to replicate the same green colour with his mixture.
any tips?
https://www.sau.com.au/forums/topic/284301-the-restoration/#findComment-4865220
  • 2 months later...
    • Hey Nismo, any chance in the world you still have these seats?
    • I'd say closer to OG GTX3582R, just smaller trim - so 59mm inducer/82mm exducer as opposed to 62/82 for the first gen GTX3582R. Yeah EFRs were boss, the EFR8474 is still an absolute beast and it perplexes me that people still go to things like Turbosmart/Garrett etc when the results people are getting with those are pretty unremarkable compared to what you could get with a turbo available well before those options came out.  DriftSquid (I think) "upgraded" from an EFR9174 to a Turbosmart turbo and promised a comparison video - and kinda shuffled awkwardly and did a bit of diversion from the fact that they didn't get any improvement going to the currently massively hyped brand of turbo from a turbo that was a bit of a frankenstein that had been well superceded in it's own range before the Turbosmart unit he put on there even came out. I suspect the EFR would outperform most Xonas for what a lot of less-insane RB owners would go for, in the 400-600kw range but the Xonas are looking hard to beat up to maybe in the mid 700kw range at this stage- basically where EFRs don't really reach, and before the Precision turbos take over.  What the Xonas do well in the "EFR range" is be easier to package etc, and work very well if a divided housing doesn't suit your application.
    • Are you sure the gasket is blown? What are the issues? Thermocure is the only flush I've seen do anything with rust, very impressed with that, Prestone, rust will be by the pool having a cigarette.
    • And since the flush you have a blown head gasket? Have you lifted the head off yet?
    • The answer is to get a hold of the wiring diagram, work out what voltage is supposed to be where, when, and then work out why it is not there, then. I can't speak to the HR34 stuff, because I have never paid any attention to the NAs. There is a possibility that the turbo diagram will help, but it could also be different - depending on whether there is an FPCM on the NAs.
