R35 Gt-r Owners Age?
rehab2010
 Share
Owners age poll
385 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Didn't vote because I don't have a R35 but would be interested to know what industry the buyers are from - motor, IT, medical, finance etc?
Just curious not doing market research or anything like that.
Oops, just noticed that my poll doesn't account for 45-50 year olds - oh well, put the age that you feel like, if you are in the missing bracket. I know some people in late 40's that feel like 25 year olds but some look and feel like they are 70 hehehe.
well the family business is going awesome thanks to the government and their over spending..... hopefully before christmas there will be another 2 votes on here, one for <25 and the other for 40-45....
although dads looking at muchialagos and 911's ..... ima get an appartment first, then an R35 in black or silver
oh and the industry is building supplies with government contracts.... but untill recently i was in the medical/pathology side of things
should have added a "I don't have a 35 I'm just here because I'm a dreamer option" :D
yes you did with your "50 and under" option (ie last one) ;)
you didn't account for anyone over 50! which is probably quite a few!
"50<" is equivalent to ">50", although it is far less elegant, so yes he has provided for the 'older' people.
i didn't vote, but i'm almost finished my law degree... perhaps sometime between 30 and 35 ill be able to make a more significant contribution to this thread ;)
The quicker they depreciate Ric, the younger the age demographic will be LOL
medical, a lot of eurosnobs in medical though.
Damn straight, once I'm done with being an intern it's BMW-ville for me ;) Would still like the 35 though (just need to convince the wife that it's technically NOT a boy-racer car like the past few have been)
Damn straight, once I'm done with being an intern it's BMW-ville for me :D Would still like the 35 though (just need to convince the wife that it's technically NOT a boy-racer car like the past few have been)
BMW???? Go Merc instead.... everyone has a bmw.... nothing bmw has goes like an sl63 or sounds like it
I want boost and something cool, so that limited me to an SL600 or a 335Ci....the 335Ci wins for many reasons (PRICE, PRICE, PRICE....oh and Chiptorque) :D
Damn right - which makes me think that the R35 GT-R is the ultimate expression of the midlife crisis hehehe.
This is prolly not true for USA or Jap since the price there is much better aligned with earnings of the majority of younger enthusiasts, but in Oz - 40+ year olds will be a great majority of owners.
Ah true - my bad (yes definitely less elegant)
Damn straight, once I'm done with being an intern it's BMW-ville for me :laugh:
Maybe one of those new 805i's Dan?
I assume this isn't a photoshop, as the car is russian and they are just crazy enough to do that.
That car needs to be confiscated and the guy sent to one of those russian places where no one ever returns...
I want boost and something cool, so that limited me to an SL600 or a 335Ci....the 335Ci wins for many reasons (PRICE, PRICE, PRICE....oh and Chiptorque) :laugh:
cl 65 is BI turbo, not twin turbo lol.... 500k new, 200k after 1 year and 5000-10000km on the odometre..... get a year old one lol
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
