Full Power Fc Tune For R33 Gtst Prices? Status, Recustoms?
hey guys just wondering where you guys got your power fcs tuned and are happy with the job and how much they charged , typical mods, turbo, fmic, z32, injectors,exhust, for example how much would somewhere like status or re customs charge?
it depends as the AFM and injectors may need more work to have them tune
and you should clarify what you call a "tune" as it might not be the same among tuners
some may just give you a max power tune and some may give you an on-road tune
and some may do a combination of both
if you just get a max power tune, youll likely have sucky fuel economy
so be sure that fuel economy is setup and tuned
and if its just a dyno tune, its likely when you get the car and trash the pants off it on the street, that it will knock
as the load is slightly different on the dyno, so either take note of this or enquire if an on-road check/tune is needed
my max power GTST tunes have been around $400 ish that was back in 2005/2006
and it was setup of car, max power tune, quick economy trim
more work was required to fix on-road knocking and on-road fuel economy later (these would be seperate costs i assume? - i did them myself)
got mine tuned at chasers motorworks (West melb, dynon Rd) . got 340kw at all 4 wheels really happy with the tune. chargers depends on how long Paul (Tuner) takes. chargers per hour. u can let him know what you want and he will work it out for ya :down: give them a ring or go down for a chat! friendly bunch of guys. who knows i might be there as well. haha. grey r32gtr, mension ken they shld know me. lol..
Edited by ujin
thanks guys yeah i was reading about the different type of tunes and how people are getting knocking on the street, thanks ujin ill have a chat to them when im ready for the tune .
It's all subjective in a lot of cases. People get quoted $500, and it turns out to be $1000.
So just go there, discuss with the people, get a price. If your car has issues on the dyno, price will go up, simple as that.
No-one can give you a concrete price due to potential problems (ie a fuel reg might die, fuel supply might be shit, parts might be intermittently faulty).
All of which takes time to diagnose and price - goes up. Hence the increase in costs.
Couldn't agree more Ash. I had issues with my fuel pump and had it replace with a Tomei @ Racepace when my retune was done because the first "cheaper" tune I has was rubbish.
Number: 9762 9421
Trent quoted me 550 I paid 550 although it went fairly smoothly at first he was worried if i had enough spark in my coil packs but he said they ended up being fine although I think he said he's bumping the price up to $570 for first tune now
thanks james yeah i heard the price went up just wasnt sure by how much i would be happy with that price for a good tune and happy to pay abit more if needs more attetnion
well status is $570 now as james was only there recently.....
but with trent, that $570 buys you a VERY good tune. and unlike many other tuners, he will fix up any issues that may arise on the road for free, and he then charges a lot less for subsequent retunes when you have new mods :(
i have my car tuned at status, and am very very happy with it... unopened rb25 makes 300rwkw and has been alive for nearly 2 years now
trent spends a LOT of time tuning every car, you really do get every dollars worth
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
