Full Power Fc Tune For R33 Gtst Prices? Status, Recustoms?
hey guys just wondering where you guys got your power fcs tuned and are happy with the job and how much they charged , typical mods, turbo, fmic, z32, injectors,exhust, for example how much would somewhere like status or re customs charge?
it depends as the AFM and injectors may need more work to have them tune
and you should clarify what you call a "tune" as it might not be the same among tuners
some may just give you a max power tune and some may give you an on-road tune
and some may do a combination of both
if you just get a max power tune, youll likely have sucky fuel economy
so be sure that fuel economy is setup and tuned
and if its just a dyno tune, its likely when you get the car and trash the pants off it on the street, that it will knock
as the load is slightly different on the dyno, so either take note of this or enquire if an on-road check/tune is needed
my max power GTST tunes have been around $400 ish that was back in 2005/2006
and it was setup of car, max power tune, quick economy trim
more work was required to fix on-road knocking and on-road fuel economy later (these would be seperate costs i assume? - i did them myself)
got mine tuned at chasers motorworks (West melb, dynon Rd) . got 340kw at all 4 wheels really happy with the tune. chargers depends on how long Paul (Tuner) takes. chargers per hour. u can let him know what you want and he will work it out for ya :down: give them a ring or go down for a chat! friendly bunch of guys. who knows i might be there as well. haha. grey r32gtr, mension ken they shld know me. lol..
Edited by ujin
thanks guys yeah i was reading about the different type of tunes and how people are getting knocking on the street, thanks ujin ill have a chat to them when im ready for the tune .
It's all subjective in a lot of cases. People get quoted $500, and it turns out to be $1000.
So just go there, discuss with the people, get a price. If your car has issues on the dyno, price will go up, simple as that.
No-one can give you a concrete price due to potential problems (ie a fuel reg might die, fuel supply might be shit, parts might be intermittently faulty).
All of which takes time to diagnose and price - goes up. Hence the increase in costs.
Couldn't agree more Ash. I had issues with my fuel pump and had it replace with a Tomei @ Racepace when my retune was done because the first "cheaper" tune I has was rubbish.
Number: 9762 9421
Trent quoted me 550 I paid 550 although it went fairly smoothly at first he was worried if i had enough spark in my coil packs but he said they ended up being fine although I think he said he's bumping the price up to $570 for first tune now
thanks james yeah i heard the price went up just wasnt sure by how much i would be happy with that price for a good tune and happy to pay abit more if needs more attetnion
well status is $570 now as james was only there recently.....
but with trent, that $570 buys you a VERY good tune. and unlike many other tuners, he will fix up any issues that may arise on the road for free, and he then charges a lot less for subsequent retunes when you have new mods :(
i have my car tuned at status, and am very very happy with it... unopened rb25 makes 300rwkw and has been alive for nearly 2 years now
trent spends a LOT of time tuning every car, you really do get every dollars worth
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
