I just put my pFC into my GTS-T and things are not going well.
I am just running with the base map at the moment and have it booked in for a tune for late jan.
I have a turbo smart bleed valve running 13psi on high and stock on low (about 7psi).
When i have it set to high boost the car runs like some body has put a orange up the exhaust (it almost feels like some sort of really fine ignition cut)?
On stock it run OK, I though it might be the fact that the PFC's base map is not designed for our fuel, or maybe the PFC does not run with bleed valves?
PS, there are no warning lights displayed or anything like that and the car is holding boost so I dont think there are any leaks in the piping for the FMIC or anything like that.
Any idea's
https://www.sau.com.au/forums/topic/28439-pfc-pro-help/
Hi GunMetalR33, I would have someone watch the Commander readout when you are driving it at full boost. If it is retarding the ignition timing or adding some fuel it will show up on the screen. This is not dangerous, in fact the ECU is protecting the engine.
Another issue may be the AFM maxing out its voltage, this is a dangerous situation. You can also easily see this on the Commander. If it is running lean it will result in knock which will show up on the dashboad warning light as well.
I would try running the boost at 10 to 12 psi and see what sort of results you get. It may be at 13 psi you are just "over the limit".
Hope that helps
https://www.sau.com.au/forums/topic/28439-pfc-pro-help/#findComment-589765
The base map may be fine for some people but it may not be fine for everyones car with infinite variety of modifications.
I would be watching the commander very closely especially the knock sensor reading.
I found that with the base map on my car it knocked too high at full throttle so i pulled it out until I can get it tuned.
https://www.sau.com.au/forums/topic/28439-pfc-pro-help/#findComment-590098
I ran for ages on base map, but with only 0.6bar boost.
When my car went on the dyno to be tuned, I was glad I had kept the boost low, as it was still running very rich on boost and had AF ratios in the 10s.
Once it was tuned at 0.8 bar, with AF ratios at 12, it still had nearly 90% injector duty with stock injectors and fuel pump. Also, my AFM had run out of resolution (5.115V) by this stage too.
https://www.sau.com.au/forums/topic/28439-pfc-pro-help/#findComment-590157
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
