This thread is interesting.
I have just started using my track R32 GTS-T on the dirt stuff as well. Although I cannot compete in the full on dirt rallies as yet, I have entered into the North Queensland Khanacross series. The car is all caged out and cams log booked and I am just waiting for my rego to come through so I can enter in the dirt and tarmac rallies at a higher level.
These photo's are from two weekends ago up in Mossman.
  • Replies 53
Posted Images
What are peoples thoughts on actually needing turbo power in a 2wd rally car? Iam not sure, seems to just turn them into a tyre lathe.
I say this because we run a 4AGE Sprinter with a massive 80 odd rwkw (Stockish motor with quads) in the Tasmanian rally series and we are keeping up with and even beating some of the 4wd turbo cars. And there is a 2wd N/A SR20 Sunny Gti down here that regularly makes it onto the podium.
I think we need that Formula Atlantic engine to keep up with the Gti though!
A pulsar SSS with the SR20DE would destroy a stockish turbo RWD skyline... NA torque is where its at. My 1600 had a class winning motor out of a 180B put into it... in the hills on tarmac or gravel it was a SHITLOAD of fun!!!!!! short gearing, response/torque, this is why a 3.4L R31 would be my pick, and shells are peanuts
looks like GREAT fun
I've been running an R32 rallycar for about three years now over here in NZ. Built it up from a road car.
The car started of just as a taily tank slapper on gravel, but over time we've developed the suspension and got it handling. It's such an unorthidox car with pretty much 70:30 weight split, apparently totally wrong for rallying, but we've proved them wrong with some good results, class wins and a 1st 2wd overall in sprints.
The car is built to our cc capacity rules, so it is still a 2ltr N/A with head work and ITB's.
A Silvia/180 etc would be a better car to start with, better weight ballance and the SR20 is a good donk to get N/A grunt out of. I just wanted to do it different and run a 6.
Edited by screamin'
no matter how much better FWDs are on gravel, I still wouldn't rally one.
same goes for a NA Silvia or Skyline. Everything is better with turbos! The only thing I own with wheels that doesn't have at least one turbo is the camper trailer!
ITB sounds great!
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
