Yes they fit a r31
brake deflectors. Laser cut alloy, professionally folded and Tig welded and Powder Coated.
Stainless cable ties to secure to radius rods and button head Allen Key bolts and nuts to secure to the lower control arms. Fits all Nissans other than GTiR and GTR.
$190 retail for the kit FATZ price $150.[/b]
I have a similar set on my gtr they roc(if you want on for your gtr I can get them as well)
Basically they cool the brakes more which in turn makes your pads last longer
Johnny has tested them and they reduced the rotor temp by 150 degrees
I used them at the philip island 6 hour race and they made a large difference to pad life and the brakes didn’t fade
Group buy will go for the next two months but get in now and ill have them off asap ( eg I should have the first delivery tomorrow)
Lets say 20 delivery throughout Australia
Bank details
Peter carruthers
Acc number 428 965 807
Bsb 112-879
Please once you deposit cash call me on 0448468884 and tell me you have.. then pm me with your address, name and mobile phone number. Just makes tracking easier
Note when you put them on depending on the offset of your rims they may scrub a little at full lock) this happens on cars that when at full lock you rims rub on your lower arm. This is quite common and I had to chop a few chunks out to clear the rim and rubber
Either way they fit nicely however be aware that they may scrub a tad at full lock
So basically no really good if you’re a latte drinking carpark driver… however if you hit the track heaps they rock!!!
Pics of the gtr specific ones on my car
just double checked with johnny and its 20 deliver but and 150 for the deflectors
keep it real!
https://www.sau.com.au/forums/topic/284424-brake-air-deflectors-150/
I've got the GTR ones on my R32 GTR and they work a treat, they did require alittle modification with a angle grinder (check uploaded pic) but otherwise I can full lock both ways without scraping my wheels (stock 16" gtr wheels with 225's) on them. Just a word of advice when you get to fitting these, GTR's radius rod are bent straight out the factory, to accommodate the GTR wheels so don't stress over them being bent.
  • 4 weeks later...
  • 3 weeks later...
still available? and any point for the average track punter? (ie, 2-3 times a year)
Definitely worth it, will extend life of rotors and pads, and help prevent the brake fluid boiling.. nothing worse than going off the track when the brake pedal is pressed to the firewall.
  • 1 month later...
No. I was contacted by unique and they said they weren't making the gtr ones for a couple of months, supposedly theres meant to be a refund organised but I haven't heard since.
  • 1 month later...
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
