  • Replies 95
Attendance list so far.. Still need to advertise on some other forums..
Rough attendance list so far. Still need to advertise elsewhere..
Coming
Basti - R33
chaddy - R32
JD - MR2
clubspec2 - WRX
blk_sz - R33
kamikaze - R33 GTR
krzysiu - R33
myRB25DET (SAU) - R34 + S15 + SSS
33gtst (SAU) - R33
mic300zx (aus300) - 300ZX
twnj3t (aus300) - 300ZX
Maybe
red32 (aus300) - 300ZX
philmak (SAU) - S13
kez - Supra
sharnie - MR2
LEANBAC - S14
ss07 (SAU) - R34
GTTR34 (SAU) - R34
tavstar (SAU) - R34
G-TR 32 (SAU) - R32 GTR
w0rp3d - R33
wcsdzblade - MA70
so whos bringing what?
Good question!
I'll be bringing a few nice steaks and some flavored snags.
Basically if everyone brings something different we can share it around.
i.e. "Hey man, I'll give you a sausage for a little bit of your potato salad" ;) You get the idea.
Hm, i'm a new member and i'm getting my licence like on the 9th of September, but would anyone be passing Cranbourne :D? I'd be down to go, seeing as i have work off that day. I'll bring meat :$.
Edited by DSYRD31
Good question!
i.e. "Hey man, I'll give you a sausage for a little bit of your potato salad" :D You get the idea.
Kris and I have opted for a last minute decision on the food front. So...no idea yet ;)
That's our simple little map :thumbsup: Quite easy really.
Oh, and who's bringing what?
If someone could bring some utensils and something to clean the BBQ with it'd be good.
i might come by,
will have to take it easy in the hills,
still getting mad vibrations from my flatspots at DECA
Remind me, looks like i'll have the 32 back!!!
kate and I used to always go there with people for BBQ's, and its getting back to that weather... I will be taking it easy, havent had the 32 for a month, and changed a lot since then.
change those over to those 5 stud hubs, with new rims and tyres. problem solved....
ehaehaea, if its snowing youll be fine.
i might come by,
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
