Sei Cruise + Bbq Day! (all Imports Welcome)
jezza boii
 Share
  • Replies 95
Attendance list so far.. Still need to advertise on some other forums..
Rough attendance list so far. Still need to advertise elsewhere..
Coming
Basti - R33
chaddy - R32
JD - MR2
clubspec2 - WRX
blk_sz - R33
kamikaze - R33 GTR
krzysiu - R33
myRB25DET (SAU) - R34 + S15 + SSS
33gtst (SAU) - R33
mic300zx (aus300) - 300ZX
twnj3t (aus300) - 300ZX
Maybe
red32 (aus300) - 300ZX
philmak (SAU) - S13
kez - Supra
sharnie - MR2
LEANBAC - S14
ss07 (SAU) - R34
GTTR34 (SAU) - R34
tavstar (SAU) - R34
G-TR 32 (SAU) - R32 GTR
w0rp3d - R33
wcsdzblade - MA70
so whos bringing what?
Good question!
I'll be bringing a few nice steaks and some flavored snags.
Basically if everyone brings something different we can share it around.
i.e. "Hey man, I'll give you a sausage for a little bit of your potato salad" ;) You get the idea.
Hm, i'm a new member and i'm getting my licence like on the 9th of September, but would anyone be passing Cranbourne :D? I'd be down to go, seeing as i have work off that day. I'll bring meat :$.
Edited by DSYRD31
Good question!
i.e. "Hey man, I'll give you a sausage for a little bit of your potato salad" :D You get the idea.
Kris and I have opted for a last minute decision on the food front. So...no idea yet ;)
i might come by,
will have to take it easy in the hills,
still getting mad vibrations from my flatspots at DECA
Remind me, looks like i'll have the 32 back!!!
kate and I used to always go there with people for BBQ's, and its getting back to that weather... I will be taking it easy, havent had the 32 for a month, and changed a lot since then.
change those over to those 5 stud hubs, with new rims and tyres. problem solved....
ehaehaea, if its snowing youll be fine.
i might come by,
 Share
    • Guess I should be hunting down one of these big ol ford units then for max flow ....  I've had fresh gas in mine and it was never as cold as it is now . The compressor could have been trash though, like I said I am one example with a bunch of unknowns.
    • I don't know if anyone was seriously suggesting a retrofit of an Echo compressor in place of a more-or-less working original comp. You'd have to change the hoses at the bare minimum to do so, and that will definitely add significant cost. I had to get my hoses modded when I did the engine transplant and chose to use the Neo's AC over the even older R32 comp. That was startlingly more expensive than expected for what looks like a simple welding job, and a massive pain in the arse when it turned to have a pinhole leak in the weld too. The Frenchie's kit is for people who have next to nothing of the original system or have more than that but some of it is a bit shit and better off thrown away than salvaged. If you've got 90% of the system, you just patch it up. Mine is currently degassed because it apparently has a big leak somewhere. If I find it is the compressor, I will be looking to take my spare comp to a shop to assess and/or recondition, rather than contemplating a retrofit to anything off-brand.
    • I went and got the aircon regassed in the Stagea today and asked the guy about the upgrade to the Toyota Echo compressor. He was saying it is likely not going to be as good. It is newer but smaller and not going to pump as strongly. And it would be better to try and get a new OEM compressor. He was saying that the improvements people are seeing may be more likely due to regassing the system. I thought it was interesting to hear. Going by the sticker the system in my car was last checked in 2015. Gas was at 50% which is apparently beyond terrible. Under 80% is where efficiency already falls apart. Anyways, with fresh gas the AC is now bloody freezing. I think it may be working a bit less hard as well. I need to drive it a bit more to try it properly. Previously on hill starts it would utterly bog down the car. I'm hoping this is a bit better now. The frenchies kit looks great, but $1400 for the compressor upgrade alone makes it a bit of commitment. Very much so compared to a $150 regas.
    • Yeah, this shit is the reason dry ice blasting was invented.
    • Sweet thanks mate, I did wonder if its easier to try and find a R33 knuckle and make that fit, is it just a case of changing the lower ball joint? I'm getting drive wheel speed off the gearbox speed sensor which is fine so far to 230kph
