  • Replies 72
Posted Images
just front , it come with other bushes but not the smal ones, i was going to change smaller ones as they don't look too healthy.
i looked thru whiteline site and couldn't find those small ones??
maybe just go to pedders and get new ones?
or if anyone knows a part number so i can order from whiteline?
https://www.sau.com.au/forums/topic/284439-swaybars/page/2/#findComment-4789993
Just go down to your local suspension shop with those bushes hopfeully they can supply some matching bushes if you are worried about replacing them.
Did the kit come with the new front links (without bushes) or do are you using your existing links?
https://www.sau.com.au/forums/topic/284439-swaybars/page/2/#findComment-4790002
Can anyone give me a heads up on what combo of swaybar stiffness would be best for GTST....? I'm guessing stiffer front than back but then my problem is... how stiff are the stock GTR rear ones? (25mm hollow) since thats what I'm fitting... Ultimately what I need to know is what best matches the GTR stock rear bar... any constructive feedback would be appreciated
https://www.sau.com.au/forums/topic/284439-swaybars/page/2/#findComment-4790260
Does anyone know if you can get adjustable 27 (front) and 24(rear) bars? I only see fixed models of these bars.
Has anyone used the 24mm rear bar?
You can get adjustable 27mm Front and 24mm rear bars from Selbys, Just picked up a set from SK :D Havent installed yet but will be over the next week or so
https://www.sau.com.au/forums/topic/284439-swaybars/page/2/#findComment-4790433
Awesome, thanks for confirming! These are the ones I am after.
From what I understand, the 27mm adjustable front / 24mm adjustable rear are more suitable for track use or with R compound tyres, the normal combo as others have posted is a 24mm front adjustable / 22mm rear adjustable combo.
https://www.sau.com.au/forums/topic/284439-swaybars/page/2/#findComment-4790676
I drove a 370Z last night, the thing handles like it is glued to the road!! My god!! Best handing car i have ever driven. I think im going to change my front 27mm one to a 24mm adjustable to fine tune it a bit more.
Edited by PM-R33
https://www.sau.com.au/forums/topic/284439-swaybars/page/2/#findComment-4790953
Do you think the front 27mm bar is too hard for your use? Which rear bar do you have?
https://www.sau.com.au/forums/topic/284439-swaybars/page/2/#findComment-4791057
I'm not sure honestly. However when pushed really hard on a down hill corner at a decent speed it will start to understeer mid corner. When driving at normal speeds into corners it is absolutely fine, only when pushed very hard. This could be due to wheel allignment, the car being to low, my driving method or the front swaybar being too big. So i'll play around with it a bit more, i just kind of wish i got the adjustable ones now. I just want it to handle as good as that 370 :thumbsup:
My rear is the 22mm fixed. These were the part numbers that Sydneykid wrote in the group buy.
Edited by PM-R33
https://www.sau.com.au/forums/topic/284439-swaybars/page/2/#findComment-4798666
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
    • And now the bloody flapper is jammed slightly open. Lazy as all f**k in 3rd-5th (very hard to convince it to make much boost before you run out of revs), but will make 12 psi in 1st, which shouldb't be possible with a 5 psi spring and controller set to <10 psi. Methinks I'm lucky it jammed where it did, rather than fully closed. It's actually a well weird situation. Careful examination of what's happening in the back of that housing when the gearbox comes out and all the other stuff (injectors, AFM retune) is supposed to be done, next week.
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
