Ok, some of you are going to kill me for this post (hear me, Nelson?)
To those ricers that fits HID 6000K or above on your cars... u suck...
Stick with OEM 4300K, they're white, they're not yellowish.
Choosing an HID bulb that have less blue tint makes it easier on your eyes for long drive.
I admit I was one of those showoff ricers who fitted a bluish tint bulb on my 93 Galant when I was in Uni, and yeah, while it's for showoff,
a quick drive on the twisties revealed that I felt the bulbs did not produce as much light as I would expect or was advertised by the manufacturers.
Yes, I was a victim of fashion, and lucky I didn't pay the price by crashing into an obstacle or kangaroos on a dark, deserted, mountain road.
Things why you should never put on blu-ish headlight bulbs on:
1. Human eyes treat blue as glare and would cause pupil to be less dilated, causing reduce night visibility.
2. The higher the colour temp, the less lumen (light output) the bulb produce as well.
Oh yes, some of you may think the higher the colour the temp, the more light, is it???
WRONG...
The higher the colour temp above 4300K, the LESS the light output will be.
Why would do you reckon European car manufacturers, after all those R&D, chosen 4300K as the best HID bulbs to be fitted on cars?
Do your research... and convert before someone gets hurt from using the wrong HID bulb on the car...
Here's one website to explain why the higher the colour temp it does not make it better.
http://www.autolamps-online.com/hidonline/...scolourtemp.htm
Below is also a comparison where the left side of the photo is using 4300K HID bulb & right side using 6000K.
as you can see 4300K emits more lights than 6000K.
The more I do search on various international forums, the more I am convinced that going 6000K or above is not the best decision to make,
except for just some wanking showoff factor...
Now... let the flaming begins... especially from 6000K lovers...
https://www.sau.com.au/forums/topic/284449-car-education-get-to-know-your-hid/
actually the best is 4100K from the chart. but due to availability of products on the market, i choose 4300K. if for some reason you felt 4300K still has a bit of tint yellow based on personal taste, try finding 5000K but I haven't found much HID bulbs out there outside the normally available 4300K 6000K and so on...
If it's done properly and not blinding oncoming drivers there are no reasons why it would give you troubles...
The best is to reuse the OEM ones, as some aftermarket kit can easily throw the adjustment off the line, and most important
your headlights should be a RHD JDM spec, don't put LHD USDM G35 headlights as they'll stuff up your beam dispersion the wrong way.
Keeping your headlights clean all the times also helps, or if you're very worried, i'm sure adding a couple of jetwashers on your front bumper directly across from headlight is easy to do.
If your compliance workshop threw yours one out (the ballast, ignitors, etc) then your best bet is to search through yahoo auctions or buy it off from someone here...
I agree with your write up Rianto, however I find it strange as my mate had diamond white 6000k on his car and they were as it says diamond white, and didn't seem to emit a tinge of blue... confused!
Actually the similar set to the one I have forsale below...
Edited by Pulp
6000k is bordering between starting to emit visible blue tint... depending on the shape of the reflectors on his car if it is designed to take HID as standard it may not emit as much blue-ish tint, however if compared side by side with 4300K the 4300K would provide more light output.
There were discussions about BMW cars having a slight tint of blue but it actually is where the light cutoff are, when you're driving from opposite the car then you passed its cutoff point then you'll see slight blue tint, all HID reflector does that, even though they had 4300K standard bulbs. it will just be more prominent on the higher colour temp level...
I've driven on 6000K bulb before and to my eye behind the wheels, it is slightly blue-ish, very faint... once u go beyond it it gets worse...
what car does he have? R33?
either the shape of his reflector, or is the kit really as advertised? e.g. there's no telling if the kit is actually 5000K but was advertised as 6000K by the manufacturer for some 'marketing' reason?
Hehehe....
4300k sucks....LOL...(just to tease u)...Agree with 4300k emitting more light....
I know where u r coming from with respect to the ricer feel...Some 'ricer's do up their cars nicely, while others r try-hards...(e.g. I saw some jap car with blue haze lights on the freeway at nite and the idiot; thinking he was cool; didn't have his headlights turned on. How wannabe-tryhard is that????)
Anyway, back to the topic, I'll personally go 6000k, nice and white (and just getting into the blue)....Anything above 6000k is fugly i must say...(And also attracts the boys in blue)...
My factory 4300k HID is going to be for sale soon as I find it not 'white' enough...I am going to 6000k HID D2Rs for low beams and 6000k HID H4 for hi/lo beams...When I get some time...
I've been waiting for your post, Nelson ha ha ha
when you mean your 4300K factory is for sale do u mean just the bulbs or the whole ballast thing?
Are you going with aftermarket ballast on the hi beam H4 or is that just a normal halogen with higher colour temp?
I found those blue tinted halogen really sucks... they are not that bright to start with (HID is a lot brighter than halogen)
and they added a blue tint to get to the colour temp which limit the light even further....
Rs73,
What you have said in the posts above are correct (i'm a light/torch freak.. have 35watt hid searchlights for toys and handheld maglites putting out the same light as a car on high beams)
HIDS to be properly legal on cars... the car needs a headlight washer system. The reason being if you have a dirty headlight and HIDs, it can cause glare to oncoming traffic.
My mate had a 6000k kit for awhile, it was a little blue to my eyes.. looked not bad though. But 4300k ftw.
some Xenon fitted R34 (dealer option) are legal without washer system, because they have an auto-leveling system. I've seen one in compliance shop and it's complied alright.
auto leveling is another alternative requirement when headlight washing system is not available...
but again even if your car has been fitted with auto levelling and/or washing system, if the reflector in the headlight was designed for halogen and it's fitted with HID bulb, it won't be legal, because the beam pattern will just go wrong.
  • 4 weeks later...
hi Rianto,
I'm looking at replacing the D2R bulbs on my car with 4300k bulbs. Any ideas of the best (cheaper) place to get these?? Do you have a owners manual with diagrams on how to replace these bulbs??
Cheers
I'll try find a DIY on this from the G35 forums. It would be strange that you'd need to remove bumpers to get to the lights, coz i think only the driving lights are HID, the highlight looks like normal halogens so there must be an easier way to get to them.
there is no easy way to get to them. these xenon bulbs are not meant to be replaced for the lifetime of the vehicle, I have looked around behind the lights from engine bay there's just no way to access it... from the wheel shroud might be another idea...
I think Nissan designed the lights to be non-user-serviceable item... for most common people who cbf diy.
if the high beam bulb is burnt, then its kind of like "replace it at your next dealer service"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
