driving home and as soon as the car hits 3000 rpm it decides it wants to stall,,,,, not stright away but eventually does after spitting for a bit,,,, then it wont start again for about 5 to 10 min.
the idle is a bit lower than normal aswell... bout 600.....
any ideas?????
https://www.sau.com.au/forums/topic/284458-rb-25-wont-rev-over-3000-rpm/
can you hear ur fuel pump whining in the boot?
Engines need;
Compression, Fuel, Air and Ignition to run.
Air is usually not a problem, and ud know if you had no compression, so check Fuel next, does sound like a AFM plug loose tho
fuel pump is humming away....... compression is good....
ill clean the afm tomoz and reset the ecu see if that makes a differance........
maby injectors blocked????? or fully open?????
is it only if you are giving it a boot or is it even under light acceleration? if only when you give it the beans then it could be that once it comes on boost it is forcing open a gap somewhere (such as a split cooler pipe or joiner) which is making it run very rich and making it stall.
any ideas?????
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
