That's fair enough Snow, but I do assume that setting a car up for circuit as opposed to tarmac rally is quite different.
For instance, my car is quick with shit in it on the circuit, but I bet it aint quick with the same shit in it on a rally stage, but it sure was with the DMS in it. I'm glad you haven't asked me what spring rates I ran in the DMS at Targa. LOL
how is the best way to pick spring rates? we have run 310/210 on the gtr 07/08, dunno what was in it this year. and the car was very nice. but by the sounds of it you were running rocks in the much lighter car. is it just trial and error?
  • Replies 95
For circuit racing I ask the tyre engineer what effective spring rates his tyre likes. After all that’s the point of contract with the road and optimising tyre traction is what it’s all about. In a RWD car I use that as my target front effective spring rate, then let the weight distribution of the car tell me what effective spring rate is needed in the rear. Note the term "effective spring rate" that is the actual spring rate divided by the movement ratio and then the leverage ratio. The tyre only feels the effective spring rate, it doesn't care what the actual spring rate is.
For a tarmac road event, using the same tyres, I would come down in spring rate in comparison to what I would run on the track as the average road surface tends not to be as well looked after as the track. Plus we have to be aware of the possibility of rain if its a long event like Targa Tas. Somewhere between 10% and 20% lower has worked for me in the past.
Cheers
Gary
The reason why helper springs are not used is simple cost, they can keep the cost down by leaving out the additional components.
By shortening the shock body you are reducing the droop travel of the suspension. A simple example of the effect of that, go over a bump of sufficient amplitude and the reduced travel means the wheel lifts off the ground after the bump. Obviously not an ideal situation on the road, but equally so on the track where I often see cars with too little droop actually lift both of the rear wheels off the track under brakes. Not a nice situation if you are trail braking on turn in, usually a spin is the result.
Just thought I'd re-itorate on this one as I didn't pick it up earlier. The PSS9/10 front coilovers don't have separate ride height and preload adjustment like the Ohlins DFV do, hence the DVF don't require the helper springs as they maintain full travel.
IF you guys don't mind, I'll throw in a slightly off topic question.
I have a 5-6 years old Bilstein coil over system for a mainly track car. Last time I took it out, I felt that it had a bit more body roll than usual but a lot of things were not perfect for racing either so it might not be the shocks.
How often do you need to reservice the shocks/spring?
What are the symptoms when the shocks goes off?
Just a bit of an update for anyone interested. I went for a ride in a friends Boxster S club car which had just been fitted up with Cargraphic fettled KW's (not sure of exactl model, but above the Clubsports and had remote reservoirs, circe 6-7k worth) and they rode really well. I was very impressed with them.
They seemed to control roll quite well considering stock swaybars, and the ride quality was better than my stock 06 STi. My mate was also really impressed with them on the track. Thought some people may be interested.
interestingly I think nfi does have a fi in this case!!! :) if he is who I think he is... possibly works somewhere on princes h'way.... starts with an "H" and ends with a "easmans"...
Haha...no that would be me...!
Yeah well I know one R33 GTR that has some MCA's in it and it's very average. It was used at Targa and had no end of problems as well. The guy who drove it there hated it and sold it straight afterwards and by all accounts the set-up on it is still shocking to this day.
I can't say for sure who was responsible for the settings in the car as it sits now, but if it came with Murrays recommended settings for that car for Targa and nothing has changed then I think you are going to have to spend some time finding what works for you (unless you either get lucky or else can pinch someone else's data who has the same basic car) if you go down that path.
I have no doubt Murray knows suspension as good as anyone out there - but that doesn't necessarily means he knows the atributes of all of the cars he builds suspension for and consequently the prefect settings. I know the suggested settings he discussed with me were along the lines I'd expect to see in an EVO which from my knowledge are usually fairly different to a GT-R - but he was the first person to admit that his suggestions were only a guess. So....
It may be that the shocks have bee adjusted by someone to less than optimium settings. Thats the thing with adjustables, people with little idea can easily turn a dial and throw a good setup out the window.
It would probably be beneficial to at least get them checked on the dyno. They could probably do with a freshen up after that many years.
Feel free to drop me an email if you have any other questions...
[email protected]
Haha here's hoping :P
If they perform anywhere near the set on my mates Boxster I will be over the moon, best body control and damping I've felt before. The way it took ripples was amazing so fingers corssed.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
