IM-32-FK Posted August 22, 2009 Share Posted August 22, 2009 When i search JDM yard and such all i find are turbos worth $5000. I really dont want to spend that much (dont even have that much!! ) Whats a good turbo that will give me a decent KW/HP boost? Right now ive got a HR32 gts-t running 13psi on standard turbo with a aftermarket intercooler. Link to comment https://www.sau.com.au/forums/topic/284515-whats-a-good-cool-clean-and-cheap-aftermarket-turbo-for-a-rb20det/ Share on other sites More sharing options...
32_Dave Posted August 22, 2009 Share Posted August 22, 2009 rb25 turbo, highflow or to4 Link to comment https://www.sau.com.au/forums/topic/284515-whats-a-good-cool-clean-and-cheap-aftermarket-turbo-for-a-rb20det/#findComment-4782205 Share on other sites More sharing options...
allthewaytotheskyline Posted August 22, 2009 Share Posted August 22, 2009 hks 2535. highflow. Link to comment https://www.sau.com.au/forums/topic/284515-whats-a-good-cool-clean-and-cheap-aftermarket-turbo-for-a-rb20det/#findComment-4782216 Share on other sites More sharing options...
Roy Posted August 22, 2009 Share Posted August 22, 2009 How much power do you want, do you want the engine bay to look std, Are you willing to upgrade ECU, injectors etc? There are plenty of options for a turbo less then $2000, but all the other stuff that may be required will soon add up to $5000 Link to comment https://www.sau.com.au/forums/topic/284515-whats-a-good-cool-clean-and-cheap-aftermarket-turbo-for-a-rb20det/#findComment-4782260 Share on other sites More sharing options...
IM-32-FK Posted August 22, 2009 Author Share Posted August 22, 2009 well, i am willing to upgrade whatever is needed to get maximum performance from the turbo. I have a budget of about $4500. How much are the listed turbos pushing in terms of stock PSI? Link to comment https://www.sau.com.au/forums/topic/284515-whats-a-good-cool-clean-and-cheap-aftermarket-turbo-for-a-rb20det/#findComment-4782817 Share on other sites More sharing options...
Kwyjibo Posted August 22, 2009 Share Posted August 22, 2009 I was in same situation as you and if you are upgrading turbo for decent power you will probably need to spend around $3000 minimum. You will need to upgrade injectors, fuel pump, and likely go to a Z32 AFM if you are going for 220rwkw+. If this is the case then you will need to upgrade your ecu. My breakdown has been approx: HKS2530 + HKS wastegate actuator - $1600 +$300 because I was stupid and something must have got in the intake and chipped the compressor wheel. GTR Injectors - $200 + cleaning and flow testing Z32 AFM - $300 new, I got two second hand, I think one may be fake though but I will be testing this once I have the car running well. Bosch 040 fuel pump - $210, aprox $250 new Just Jap FMIC kit - $500 Power FC - $1000, could probably get away with a second hand emanage ultimate or a toshi remap for around $700 Boost controller - $40 Turbotech but you may like to go electronic and this could cost you $200 up Front pipe/split dump - $180 Misc costs for gaskets, getting intake piping welded, oil + coolant - $200-$300 You could probably get away with less. I got a turbo that has heaps of response and decent power in very good condition. You could probably get away with a hi-flow from Hypergear or something for $800ish if your not worried about this and want more than 240kw. I'm also lucky in that I have a good clutchalready , I think you would be lucky to get away with the standard one not slipping at decent power levels. Link to comment https://www.sau.com.au/forums/topic/284515-whats-a-good-cool-clean-and-cheap-aftermarket-turbo-for-a-rb20det/#findComment-4782857 Share on other sites More sharing options...
bbe Posted August 23, 2009 Share Posted August 23, 2009 cheap 2nd hand go with rb25 turbo or vg turbo next cheapest hypergear are getting good results otherwise 2530 up till 220 you should be right with std injectors an afm. you should all ready have other supporting mods. Link to comment https://www.sau.com.au/forums/topic/284515-whats-a-good-cool-clean-and-cheap-aftermarket-turbo-for-a-rb20det/#findComment-4783936 Share on other sites More sharing options...
Super Drager Posted August 23, 2009 Share Posted August 23, 2009 cheap 2nd hand go with rb25 turbo or vg turbonext cheapest hypergear are getting good results otherwise 2530 up till 220 you should be right with std injectors an afm. you should all ready have other supporting mods. 220rwkw on 270cc injectors? Don't think so, Mates was hitting close to 100% on ~200rwkw. Should go for HKS GT2535, GTR pump, GTR Injectors, set of splitfires and and a remap. Link to comment https://www.sau.com.au/forums/topic/284515-whats-a-good-cool-clean-and-cheap-aftermarket-turbo-for-a-rb20det/#findComment-4784279 Share on other sites More sharing options...
Kwyjibo Posted August 23, 2009 Share Posted August 23, 2009 With a HKS2530 I hit 92% injector duty at 5500rpm on about 12 psi so I defintely wouldn't recommend going 220kw on standard injectors. I probably wasn't even hitting 180kw at the time. Link to comment https://www.sau.com.au/forums/topic/284515-whats-a-good-cool-clean-and-cheap-aftermarket-turbo-for-a-rb20det/#findComment-4784363 Share on other sites More sharing options...
Toshi Posted October 14, 2009 Share Posted October 14, 2009 My remap price is Z32 AFM,bigger injector,bigger turbo only $550 road tune. I tuned RB20 DET make 280-290 hp and just changed to bosch 044(bigger than 040) , GT2530, Z32 AFM,FMIC only. Link to comment https://www.sau.com.au/forums/topic/284515-whats-a-good-cool-clean-and-cheap-aftermarket-turbo-for-a-rb20det/#findComment-4881223 Share on other sites More sharing options...
