Replacement Fuel Pump
Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
This comparison table needs more MaxSpeedingRods turbos added for those off us who like the LOLs 😛
Yeah I did, was a good one Also pretty sure Xona do mirror options
Me too, I wish they did v band reverse rotation - I'd order one straight away. Did you listen to the HPA interview with one of the Xona guys, quite interesting.
