So i received a canary last night and am just curious about a few things.
Staggered wheel widths as i understand are a no no, correct? (i.e 7inch front 8inch rear)
Removal of the stock wing with LED brake light means i have to install a 3rd brake light in the window. Thats just my assumption but makes sence. Any one clear that up for me?
Finally, I too have been cursed by the dud drivers side electric window switch, so my window doens't go down at the moment. The Officer didn't pick me up on it just thought the inspector at licensing might?
Cheers,
Brock.
PS. if i could borrow anyones stock 33 rims or the day of inspection it would be greatly appreciated. money and/or "the carton" can be arranged.
https://www.sau.com.au/forums/topic/284532-yellowd/
For the brake light yes you do need a 3rd one in the middle.
A third brake light is compulsory on vehicles 1989 onwards, no more than 1.8m from the ground.
Mine never worked ever since I bought the car, I better get mine fixed soon :P
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4782519
Cheers for info!
Another quick one, I've heard people getting done for not having any water in there windscreen sprayer. My concern is on of my jets is only shooting one stream instead of two, are they that picky at licensing??
Cheers,
Brock.
Edited by BROCKDOE
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4782587
Yes, they can pick you for having low water in the windscreen washer bottle.
If it's too much hassle to fix, leave it and see how you go. The chances of them picking it are pretty slim but just be aware that they may ask to see it working.
The nozzle won't be hard to clear. My advice is spend 30 minutes to give it a go and cover all your bases.
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4782877
nephew is going through a yellow at the moment, they will check the center brake light but you can get them from repco . car must be 100mm of the ground at lowest point with 5 people and a full tank of fuel (cant believe that one), no staggered wheels. if you have a FMIC it must be permited
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4782946
FMIC's don't need permits
With the staggered wheels/tyres unless it's stupidly different there shouldn't be an issue, I passed quite a few times with 235/45 & 255/40 & they never mentioned anything to me, the only reason the yellow sticker didn't come off was because I was waiting for mods approval....
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4783276
Sweet deal. Water jet fixed, Installing brake light during the week. Might try get past with the staggered wheels, wrapped in fresh rubber too.
Any one have any idea about the electric window issue? Also I didn't think about this one until driving last night. I have blue lights in the foot area on drivers side and passenger side, should that be an issue??
Cheers,
Brock.
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4784419
Cheers,
Brock.
dude if ur worried about drivers window i got a spare one here if u need ,u can have it, it took me 6months and and engineers certificate to pass mine and they still said no ,so after the 6th time with screema pipes installed mind u , they past, make sure ur pod is secure and u have a lead free battery or one that is ventelated to outside ,any questions ,fire away ive heard it all from the wankers
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4784593
so scr33ma, whats the go with intercoolers. whats the trick with getting them passed. this is the only worry i have on mine.
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4785060
When I had mine done it had to be securely fixed. Others I have seen have stated that they had to be meshed.
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4785117
Power window issue is probably the same deal I had with mine (units may or may not be similar between 32 and 33.. I don't know). There's a little relay unit that's usually screwed to the door frame, that was dead, got a replacement from a wreck for cheap.
https://www.sau.com.au/forums/topic/284532-yellowd/#findComment-4785168
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
